tu
Time for programming 64bytes flash block |
Posted: Tue Aug 23, 2005 11:25 pm |
hi, i'm a little bit confused how long it takes to program a block of flash. i i program a 64byte - long by this command :
write_program_memory (ee_block_address, ee_block, 64);
will this take approx. the "famous" 4ms - what will happen if I use longer blocks. how long can the maximum length be defined ?
furtheron :
how long does a readback approx. take :
read_program_memory (ee_block_address, ee_block, 64);
sorry to ask these question - that one with an in circuit debugger might easy clarify - but i'm just a "poor" student with a compiler and a decent prototpying board at the fingertips;) |
