Newbie Guest
RS232 & Invert |
Posted: Sat Jan 04, 2003 9:35 am |
I have a 16F876 and I am interfacing with a GSM modem, the GSM modem uses RS232 levels that are low-high transitions, but the 16F876 uses high-low transitions (I am using the hardware RS232) and I can't change it using the INVERT statment in the "#use RS232" line, it says this is not allowed with hardware RS232.
As the GSM is designed to interface with a MCU I do not need any level shifting like a max232 I do realise if I was using a max232 it would get inverted.
I am getting round this problem by using "hex invertor" but I'd like to be able to loose this, saving cost and board space.
Thanks in advance.
___________________________
Original Post ID: 10414 |
Tomi Guest
Re: RS232 & Invert |
Posted: Sat Jan 04, 2003 10:30 am |
:=..... it says this is not allowed with hardware RS232.
Yes, that's true A bit-banged RS232 could set the output when you say "0" and vice versa but the HW UART don't have built-in inverters.
:=As the GSM is designed to interface with a MCU I do not need any level shifting like a max232
Are you sure? What is your GSM adapter type? I use Siemens M20 and TC35 and they have V.24 interface (Max232 is necessary) and I use GM22 from Ericsson. It has base-level 232 (mark is high) but need 0-3V interface. If your GSM adapter has low (or cca. -3...-8V) mark signal then you MUST use a max232. It could work with a simple '04- style inverter because most of the current line receivers (including that ones used in PCs) sense high everything under +0.3V. But IMHO it is a very dangerous mode of usage: especially you don't have a good noise protection what could be critical when the 900/1800MHz transmission starts
Additionally, if you really need an inverter then it is pretty sure that your GSM adapter has negative output what is shorted to the ground over the input protection diode of the inverter so earlier or later it could kill your adapter (except if you have a resistor between the GSM output line and the inverter's input).
Original Post ID: 10415 |
Newbie Guest
Note for Tomi |
Posted: Sun Jan 05, 2003 9:35 am |
Thanks for the reply, the GSM modem is an embedded GSM862-GSM
you can check the spec at <a href="http://www.roundsolutions.com/" TARGET="_blank">http://www.roundsolutions.com/</a>
All the different levels are a little confusing and I'm not sure I follow what you said, could you take a look at the PDF from the web site above and advise me.
:=:=..... it says this is not allowed with hardware RS232.
:=Yes, that's true <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0"> A bit-banged RS232 could set the output when you say "0" and vice versa but the HW UART don't have built-in inverters.
:=:=As the GSM is designed to interface with a MCU I do not need any level shifting like a max232
:=Are you sure? What is your GSM adapter type? I use Siemens M20 and TC35 and they have V.24 interface (Max232 is necessary) and I use GM22 from Ericsson. It has base-level 232 (mark is high) but need 0-3V interface. If your GSM adapter has low (or cca. -3...-8V) mark signal then you MUST use a max232. It could work with a simple '04- style inverter because most of the current line receivers (including that ones used in PCs) sense high everything under +0.3V. But IMHO it is a very dangerous mode of usage: especially you don't have a good noise protection what could be critical when the 900/1800MHz transmission starts <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=Additionally, if you really need an inverter then it is pretty sure that your GSM adapter has negative output what is shorted to the ground over the input protection diode of the inverter so earlier or later it could kill your adapter (except if you have a resistor between the GSM output line and the inverter's input).
Original Post ID: 10426 |
Tomi Guest
Re: Note for Tomi |
Posted: Mon Jan 06, 2003 1:28 am |
:=All the different levels are a little confusing
After a quick look on the pdf file I can understand the confusing. The only usable tech info is for GM862-GPRS but you have GM862-GSM (?)
To decide what you have to do check the voltage between pins #37 (GSM output) and e.g. #2 (Gnd). If that voltage is cca. 2.8-3V then you have to use a 3V-5V interface as described on Page#21. If the voltage is below -2V (or at least negative) then you have to use a Max232.
Original Post ID: 10447 |
Newbie Guest
Page 17 of spec |
Posted: Mon Jan 06, 2003 7:19 am |
I have not had chance to look at pin 37 as the prototype board for the GSM862 is hard to work with (multilayer) and finding a test point is hard.
I did read the spec sheet for the GSM and noticed quite a lot of into regarding interfacing on page 17, can you take a look this. I think it is saying that I am basically right in what I think.
Input High = +2.1v - +3.3v
Input low = 0v - +0.5v
Output High = 2.2v - 3.0v
Output Low = 0v - 0.35v
Max on all inputs = 3.37v
From what I can understand from all this, it means that I could connect the PIC direct to the GSM but it would require inverting.
The only concern I have it the max 3.37v as the output pin on a PIC is max +4.7v, or could I drop the PIC VSS to say 3.3v and this would give me +3.0 max? thinking about that this would not help as the "Hex invertor" I was thinking about using would be outputting +5v as a high anyway!
Just had another thought! even if I did use a Max232 would this not be outputting >+3.37v for a high!!! ahhhhhhh
Thanks again for all your help.
:=:=All the different levels are a little confusing
:=After a quick look on the pdf file I can understand the confusing. The only usable tech info is for GM862-GPRS <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0"> but you have GM862-GSM (?)
:=To decide what you have to do check the voltage between pins #37 (GSM output) and e.g. #2 (Gnd). If that voltage is cca. 2.8-3V then you have to use a 3V-5V interface as described on Page#21. If the voltage is below -2V (or at least negative) then you have to use a Max232.
Original Post ID: 10452 |
Tomi Guest
Re: Page 17 of spec |
Posted: Mon Jan 06, 2003 8:38 am |
It sounds like your GSM adapter is very similar to Ericsson GM22 what I used. In that system I simply use +3V power for PIC (16LF876). In this case the UART output is 0-3V compatible so you can connect it directly to the adapter.
HTH
Tomi
Original Post ID: 10456 |
Newbie Guest
What about the inverter? |
Posted: Mon Jan 06, 2003 11:01 am |
Can you confirm about the inverter.
The project currently uses a TC35 via a MAX232 that inherently inverts the signal and I have checked this at the Rx Pin of the 16F876 and it is inverted. if I connect the GSM862 directly to the Pic the signal comming from the GSM will not be inverted and therefore fail even if I run it at 3v, won't it?
Sorry for being stupid :o(
:=Hi,
:=It sounds like your GSM adapter is very similar to Ericsson GM22 what I used. In that system I simply use +3V power for PIC (16LF876). In this case the UART output is 0-3V compatible so you can connect it directly to the adapter.
:=HTH
:=Tomi
Original Post ID: 10466 |
Tomi Guest
Re: What about the inverter? |
Posted: Mon Jan 06, 2003 11:41 am |
:=Can you confirm about the inverter.
:=The project currently uses a TC35 via a MAX232 that inherently inverts the signal and I have checked this at the Rx Pin of the 16F876 and it is inverted. if I connect the GSM862 directly to the Pic the signal comming from the GSM will not be inverted and therefore fail even if I run it at 3v, won't it?
Huhhh, maybe the name "inverter" is not a really good name and it could make confusion.
Check the output of the GSM862. If it has a mark signal of cca. PLUS 2.8-3V then it is "logic circuit compatible" so you don't need an inverter (you wrote that you can not measure that voltage but how do you connect the adapter to the PIC?)
At the TC35 side, the LOW level is defined as "voltage is greater than +3V" and the HIGH level is defined as "voltage is less than -3V". The max232 line transceiver converts this level definition to "logic circuit definition" (high > 2.1 low < 0.5)
If I strongly understand your adapter has a DB9 connector (once more, I don't know that adapter and the info found on the web is very poor) as TC35 has but the levels for GSM862 are CMOS-compatible so you can measure cca. 3V between pin#2 and pin#5 (unplug your cable from adapter and use a plain DB9 connector).
In this case connect directly pin#2 to PIC's receive line and pin#3 to PIC's transmit line and pin#5 to the common ground.
Original Post ID: 10467 |
Newbie Guest
Think I have it |
Posted: Mon Jan 06, 2003 4:34 pm |
Right, I found the signal on the evaluation board (pin 37) that came with the GSM862. This pin is at approx 2.5v when no data is transmitting, if the GSM sends data it fluctuates between 2.5v and 0v then after data has finished it returns to a high state 2.5v.
So I think I agree with you that this will connect directly to the PIC as long as I run the PIC at 3v, do you agree?
:=:=Can you confirm about the inverter.
:=:=The project currently uses a TC35 via a MAX232 that inherently inverts the signal and I have checked this at the Rx Pin of the 16F876 and it is inverted. if I connect the GSM862 directly to the Pic the signal comming from the GSM will not be inverted and therefore fail even if I run it at 3v, won't it?
:=Huhhh, maybe the name "inverter" is not a really good name and it could make confusion.
:=Check the output of the GSM862. If it has a mark signal of cca. PLUS 2.8-3V then it is "logic circuit compatible" so you don't need an inverter (you wrote that you can not measure that voltage but how do you connect the adapter to the PIC?)
:=At the TC35 side, the LOW level is defined as "voltage is greater than +3V" and the HIGH level is defined as "voltage is less than -3V". The max232 line transceiver converts this level definition to "logic circuit definition" (high > 2.1 low < 0.5)
:=If I strongly understand your adapter has a DB9 connector (once more, I don't know that adapter and the info found on the web is very poor) as TC35 has but the levels for GSM862 are CMOS-compatible so you can measure cca. 3V between pin#2 and pin#5 (unplug your cable from adapter and use a plain DB9 connector).
:=In this case connect directly pin#2 to PIC's receive line and pin#3 to PIC's transmit line and pin#5 to the common ground.
Original Post ID: 10479 |
Tomi Guest
Re: Think I have it |
Posted: Tue Jan 07, 2003 1:29 am |
Exactly
Original Post ID: 10492 |
