I am writing a program that needs to have a 100ms delay. I am using a 16F630 processor. the problem is that when the delay routine is running, the watchdog it timing out (it times out every 18ms). Is there a way to get around it?
Fabio
Posted: Mon Aug 22, 2005 2:40 pm
Hint, read the manual for the USE_DELAY function...
valemike Guest
Posted: Mon Aug 22, 2005 4:13 pm
usafape wrote:
Duh!!!!
Don't you read the manual???
Thanks a lot!!!
Glancing at the "#use delay" description at page 61 tells you how to inject watchdog refreshing into the #use statement.
You have read it and have figured it out by now, haven't you????
