skyforme
Bra command in C. |
Posted: Mon Aug 22, 2005 2:10 pm |
Hello again.
Can I use bra command (or call or goto) outside of a function?
For example can I use like this?
#ASM
bsf INTCONbits.PEIE //LOW INT
bsf INTCONbits.GIE //HIGH INT
Main:
goto Main
PWM_INTERRUPT:
retfie 1
#ENDASM
void Int_Handler_High(void)
#asm
btfsc PIR3bits.PTIF //;PWM interrupt?
call PWM_INTERRUPT
RETFIE 1
#endasm
#org 0x08,0x0A
* DESCRIPTION: Wrapper for the high priority interrupt
* RETURN: none
* ALGORITHM: none
* NOTES: none
void Int_Handler_High_Wrapper(void)
Int_Handler_High();
For the high int wrapper, I used a function someone posted.
In addition, I still do not figure out that I can use high(ABC), low(ABC).
Please help me. |
Posted: Mon Aug 22, 2005 2:21 pm |
I think you are making it very difficult to yourself. Either program everything in assembler or do everything in C, trying to mix both will result in a program that is hard to understand now and in 6 months even you will no longer have a clue as to what you were trying to do. Another problem is that you might confuse the compiler and get unexpected results (bugs).
In C there is a convention to never use the goto instruction as there is no need to and it often results into spaghetti code. Only sometimes when programming some very low level routines like a bootloader you need the goto instruction to jump to a hard coded memory address, in CCS you can do this by calling the goto_address() function. |
skyforme
Posted: Mon Aug 22, 2005 2:59 pm |
Thank you.
It seems that make8 will the thing that I want.
Yeah..I also don't want to have mixed code.
I am just trying to be a CCS user.
Many of my code will be changed to C format.
And Mplab asm has high low operator as far as I know.
Thank you for your reply. |
Posted: Tue Aug 23, 2005 3:01 am |
The comment on this is obvious. CCS 'C', is a 'C', not an assembler. It does contain a limited assembler, but this uses 'C' conventions internally, not assembler conventions. It is possible now, to do 99+% of things directly without using assembler at all, and this is what you should be doing. For the odd fraction of a percent, the syntax is very different from the MPLAB assembler. In the case of a variable for example, you can access it using 'C' names, rather than assembler forms. So, if you have a 16bit variable 'counter', in CCS assembler, you access the low byte, by just using 'counter', while you access the high byte using '&counter+1'. If you have a fixed 'define' (perhaps #define val (0x1234)), you can just use the low byte, with 'val & 0xFF', and the high byte with 'val>>8'. These cost nothing in use, since the compiler identifies these as 'fixed' values, and does the conversions while compiling, and not when the program runs.
