How to use two ssp simutanously
young
PostPosted: Fri Aug 19, 2005 11:08 am     Reply with quote
I am thinking to use a timer chip and a MMC, they both using the SCL, SDA, Is it possible, how they recognize each other without mistake?
young
PostPosted: Fri Aug 19, 2005 12:00 pm     Reply with quote
If I define I2C to other pins like PIN_A0=SDA, PIN_B1=SCL than I can use this two pins as timer and the hardware SDA,SCL, SDO for SPI for MMC is this right?
PostPosted: Fri Aug 19, 2005 12:13 pm     Reply with quote
Who are the manufacturers and what are the part numbers of the
two chips ?
young
PostPosted: Fri Aug 19, 2005 12:28 pm     Reply with quote
Which I mean is to use a software I2C and hardware SPI
young
PostPosted: Fri Aug 19, 2005 12:32 pm     Reply with quote
I am trying to use 16f877A and PCF8583 (timer) and MMC (not sure yet as least 32MB) I would be intended to use the MMC card and programing that you post before, please advise!
Assuming you're using a 16F877, then use pins C3, C4, and C5 for the
hardware SPI, and use any other two pins for the software i2c,
such as B0 and B1.
young
PostPosted: Fri Aug 19, 2005 12:55 pm     Reply with quote
thank you:
which MMC did you used, and what is the adaptor (connect to it), can I use any large memory without modifying the program.
PostPosted: Fri Aug 19, 2005 1:13 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=23183&start=15
