Typecasting int->float
Kevin Mayer
PostPosted: Tue Dec 11, 2001 3:42 pm     Reply with quote
Consider the following (on a PIC16F877):
float f;
int i = 23;
f = (float) i;
printf("Int is \%D, float is \%3.3f",i,f);
The output is:
Int is 23, float is 22.9
Basically, whatever int I cast to a float, the float is always 0.1 less than the int - this isn't due to the lack of accuracy in the floating point number implementation, so why could this be happening?
___________________________
Original Post ID: 1576
Dale Botkin
Re: Typecasting int->float
PostPosted: Tue Dec 11, 2001 8:42 pm     Reply with quote
:= float f;
:= int i = 23;
:= f = (float) i;
:= printf("Int is \%D, float is \%3.3f",i,f);
:=The output is:
:= Int is 23, float is 22.9
Is this on a PIC or a Pentium?
8-) Sorry, but /somebody/ had to say it...
Original Post ID: 1583
Kevin Mayer
PostPosted: Tue Dec 11, 2001 9:18 pm     Reply with quote
Actually - no-one really had to say it....the first line of my post is:
"Consider the following (on a PIC16F877):"
so it's on a PIC, not a Pentium...
Original Post ID: 1584
Neutone
PostPosted: Wed Dec 12, 2001 8:21 am     Reply with quote
Their are rounding errors in the floating number format but they are not causing the 0.1 error. You can use the "Pconvert.exe" program distributed with PCW to look at this. The error you are seeing is probably in the printf function. \%3.3f should have displayed something like 22.999
Original Post ID: 1591
Kevin Mayer
PostPosted: Wed Dec 12, 2001 3:40 pm     Reply with quote
I only have the PCM compiler, not the whole PCW suite and hence I don't have pconvert.exe :(
Sorry - it was actually a printf \%3.1f - but shouldn't printf round it? (or is that asking too much?)
Original Post ID: 1602
Neutone
PostPosted: Wed Dec 12, 2001 4:18 pm     Reply with quote
Try adding .0000001 to the float prior to printing the number. It should look right to at least 5 decimal places (\%3.5f).
:=I only have the PCM compiler, not the whole PCW suite and hence I don't have pconvert.exe <img src="http://www.ccsinfo.com/pix/forum/sad.gif" border="0">
:=Sorry - it was actually a printf \%3.1f - but shouldn't printf round it? (or is that asking too much?)
Original Post ID: 1605
PostPosted: Thu Aug 18, 2005 1:42 pm     Reply with quote
I have the same problem, but is not a casting problem, the proble is in the printf function.
Anybody have a solution to this problem???
Thnaks in advance
PostPosted: Thu Aug 18, 2005 1:49 pm     Reply with quote
To fix the printf rounding problem, see this thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=23290
So, if your precision is ".1", then you add .05 to the value.
if the precision is ".2", then you add .005
if it's ".3", you add .0005
This should fix the CCS round-off problem.
Douglas Kennedy
PostPosted: Thu Aug 18, 2005 4:26 pm     Reply with quote
There is no reason why this should happen from a math point of view.
23 is an integer clearly within the range of the mantissa.
Assuming the 4 byte in float representation is accurate of the decimal value 23 then printf and its possible divide by ten logic to tease out the digits for printing is causing an error.
A necessary for accuracy move on a float before CCS attempts a printf conversion would be to first see if the value can be expressed within the mantissa with a zero exponent. This is certainly true of all integers less than 2^23. If the exponent can be balanced down to zero ( it would actually be 127 due to the bias needed to allow for negative exponents)and at the same time adjusting the mantissa for the exponent changes then printf should treat the float now as a 23bit integer. Printf can print integers correctly so it should also print float correctly. Again this is a bug probably caused by starting with the floats normalized 0.1...... binary mantissa representation rather than up shifting when they see a zero in the right most (23 bit of the mantissa) and balancing with a decrement in the exponent.
It's a bug from my point of view.
