PROBLEM: A segment or the program is too large!
gcataldo
PostPosted: Tue Aug 16, 2005 7:34 pm     Reply with quote
I’m using a CCS C Compiler to program a PIC16F877. I use that thorough MPLAB Plug-in from CCS in order to use my PICStart Plus Programmer. But when the code starts grow this error appears.
MPLAB Output Screen:
main
Seg 00800-00FFF, 0555 left, need 0829
0001
Seg 01000-017FF, 0800 left, need 0829
0001
Seg 01800-01FFF, 0800 left, need 0829
0001
Seg 00000-00003, 0000 left, need 0829
0001
Seg 00004-00032, 0000 left, need 0829
0001
Seg 00033-007FF, 002C left, need 0829
0001
@goto12216
*** Error 71 "C:\temp\c14-f2\main_filename.c" Line 203(0,1): Out of ROM, A segment or the program is too large
Halting build on first failure as requested.
BUILD FAILED: Tue Aug 16 21:12:40 2005
Can you help me?.
Thanks.
Giancarlos
PostPosted: Tue Aug 16, 2005 7:43 pm     Reply with quote
te jodiste,pues no se nada de eso pero solo te digo que tienes que hacerlo mas CORTO.
Mark
PostPosted: Tue Aug 16, 2005 7:53 pm     Reply with quote
You function is too big. Try breaking it up into smaller pieces. If you only call a function once then try adding #separate before the function or else the compiler will place the code "inline" and your function will be larger than expected.
gcataldo
Problem Solve !
PostPosted: Tue Aug 16, 2005 9:20 pm     Reply with quote
Mark:
I follow your recomendation and make it work success Very Happy .
Thanks a lot.
Giancarlos
arunb
RE:
PostPosted: Thu Aug 18, 2005 9:30 am     Reply with quote
Will writing #SEPERATE before a large function solve the problem, I have faced this problem quite frequently, what I usually do is to break the large function/procedure into smaller ones.
I did'nt know #SEPERATE could solve this problem...
thanks
arun
Mark
PostPosted: Thu Aug 18, 2005 12:00 pm     Reply with quote
It won't "break up" a large function. For example:
void funcA(void
void funcB(void
void funcC(void
void funcD(void)
  funcA();
  funcB();
  funcC();
In the above example, if we only call the functions once, funcD will be one big function. That is, the compiler will place the A,B,C functions "inline" as an optimization technique. By adding #separate before functions A,B, and C, the compiler will treat these as individual functions which would be smaller and have a better chance of fitting into a code page.
PostPosted: Thu Aug 18, 2005 12:06 pm     Reply with quote
If you're using #separate with the 16F series, read this thread for
the limitations:
http://www.ccsinfo.com/forum/viewtopic.php?t=12384
