Re: 16F877 and 18F452 RB interrupts |
Posted: Mon May 19, 2003 1:15 pm |
:=I was using the RB (pins 4-7) interrupt on an 16F877 without any problems. I needed more programming space so I went to an 18F452. I can not get the RB interrupts to function. Are there additional settings for the 18F452 that are not required for the 16F877 for the RB interrupt to work?
In your 16F877 code, do you have something like this:
#byte port_b = 6
so that you can clear the "change" condition by reading
the port in the isr ?
ie:
#int_rb
void int_rb_isr(void)
char c;
c = port_b;
// etc.
If so, did you change the address of Port B from 6, to the
address used by the 18F452 chip, 0xF81 ?
___________________________
Original Post ID: 144514557 |
