can watch dog wake up a processor during sleep?
jahan
PostPosted: Wed Jul 27, 2005 9:22 am     Reply with quote
I would like to wake up my processor (16F84A) from sleep using WDT.
Is it doable?
Thankx
theMagni
PostPosted: Wed Jul 27, 2005 10:45 am     Reply with quote
Yes.
You'll have to read your datasheet to find out what the WDT is going to do. It's under "special features". Check both the WDT and SLEEP specs.
For example, the 16F88 wakes up the PIC and it resumes instruction on the next line. The 10F202 resets on WD timeout.
In the 90's, I promised myself I'd never use a so-called "smiley icon". I hate what I've become. ;)
mcafzap
PostPosted: Wed Jul 27, 2005 2:33 pm     Reply with quote
This is easy provided you bear in mind the different behaviours of the various devices.
This is not a complete working program for all the usual reasons - I've had to edit it down to a minimum. It wakes up every WDT timeout, but only responds every 3rd time.
#include <10F206.h>
#Fuses NOMCLR,NOPROTECT,WDT
#use fast_io(B)
int8 sleepcount;
#asm
// Disable wake-up on pin change, enable weak pull-ups,
// Timer0 source internal, L to H
// Prescaler to WDT, max division 2304mS
   movlw 0x8F
   OPTION
#endasm
// no comparator output,
   CMCON0 = 0x73;
      sleepcount++;
if (sleepcount > 2){      //Every 3rd 'sleep' ...
         sleepcount = 0;
//do whatever's required.
// Falls off the end here because there is no 'while(1)'
// hence it naturally goes to sleep.
Alternatively for the 16F629...
#use fast_io(A)
int8 sleepcount;
#byte PORT_A = 5
#byte TRIS_A = 0x85
      setup_wdt(WDT_2304MS);
// set up port/peripherals here
   sleepcount=0;
   While(1){
      sleepcount = 0;
   //do whatever      }
   sleep();
   sleepcount++;
} //end main
Once again, not a full program, but you'll note the difference that on this device the program stays within the while(1) loop so we can safely initialise sleepcount (it never gets back out to the main() loop).
(My thanks once again to PCM for his invaluable help to me on this subject.)
HTH
Steve
jahan
PostPosted: Wed Jul 27, 2005 8:57 pm     Reply with quote
Thankx steve.
I did read the data sheet and getting feed from your code definitly helped me understand the WDT better.
-JJ
PostPosted: Mon Aug 08, 2005 6:31 am     Reply with quote
mcafzap wrote:
#include <10F206.h>
#use fast_io(B)
int8 sleepcount;
#asm
   movlw 0x8F
   OPTION
#endasm
   CMCON0 = 0x73;
      sleepcount++;
         sleepcount = 0;
Steve
In this example of PIC10F202, "sleepcount" is not initialized. Is it acceptable to assume that it starts with 0 on cold boot?
PostPosted: Mon Aug 08, 2005 6:39 am     Reply with quote
It _is_ initialised!...
if you read the manual, you will find hidden away in there, a note that global variables are initialised to zero. This can be a pain at times (when you want such variables to be maintained on a reboot).
so you can assume that any variable declared in the main 'body' like this (and hence a global variable), is automatically set to '0'.
PostPosted: Mon Aug 08, 2005 10:35 pm     Reply with quote
Then, does it actually increase sleepcount when it wakes up from sleep by WDT?
int8 sleepcount;
      sleepcount++;
PostPosted: Mon Aug 08, 2005 11:53 pm     Reply with quote
Actually, a global variable is automatically initialized to zero only if you
declare it as static. If it's declared as a global without the static qualifier,
then you have to set it to zero with code:
int8 sleepcount = 0;
The manual says this:
static: Static variable is globally active and initialized to 0
PostPosted: Tue Aug 09, 2005 4:10 am     Reply with quote
If you declare a variable as static inside a function, it is also initialised to zero, but in fact all global variables seem to be cleared (even without using 'zero RAM'). This caused me some grief in the past, and I moaned about it to CCS, pointing out that for a system using a 'warm restart' after a watchdog, I wanted global variables to be maintained, unless I specifically cleared them. If you look at this:
Variable declared external to main as:
int8 cause;
int8 ctick;
The symbol addresses are:
024     cause
025     ctick
and the asssembler generated at the start of main is:
.................... void main() {
0004:  CLRF   FF8
0006:  BCF    FD0.7
0008:  CLRF   FEA
000A:  CLRF   FE9
000C:  BSF    FC1.0
000E:  BSF    FC1.1
0010:  BSF    FC1.2
0012:  BCF    FC1.3
0014:  MOVLW  19
0016:  MOVWF  FAF
0018:  MOVLW  26
001A:  MOVWF  FAC
001C:  MOVLW  90
001E:  MOVWF  FAB
001F:  MOVLB  0
0020:  CLRF   x24
0021:  CLRF   x25
This was with 3.147, which though I have latter versions, I am still using for some code. If they have switched to not clearing globals, unless declared as static, I'll be cheering!... :-)
(I ended up manually generating the required variables in a block of memory, which I took control of).
PostPosted: Tue Aug 09, 2005 4:42 am     Reply with quote
In C++ and in ANSI-C global and static variables are automatically initialized to zero when they are declared. So this is one of those rare situations where CCS does follow the ANSI-C standard. Wink
PostPosted: Tue Aug 09, 2005 12:30 pm     Reply with quote
I can't make it zero the globals with any version I try.
I'm pretty sure that I saw it do that in the past, but I don't know with
what version. Here is a test program that I compiled with PCH 3.230:
#include <18F452.h>
#fuses XT, NOWDT, NOPROTECT,PUT,BROWNOUT,NOLVP
int8 cause;
int8 ctick;
main(void)
cause = 0x55;
ctick = 0xAA;
Here is the ASM code:
.................... main(void)
0004:  CLRF   FF8
0006:  BCF    FD0.7
0008:  CLRF   FEA
000A:  CLRF   FE9
000C:  BSF    FC1.0
000E:  BSF    FC1.1
0010:  BSF    FC1.2
0012:  BCF    FC1.3
.................... cause = 0x55;
0014:  MOVLW  55
0016:  MOVWF  05
.................... ctick = 0xAA;
0018:  MOVLW  AA
001A:  MOVWF  06
.................... while(1);
001C:  BRA    001C
001E:  SLEEP
If I declare the variables as static, like this:
static int8 cause;
static int8 ctick;
Then it puts in two CLRF statements:
0004:  CLRF   FF8
0006:  BCF    FD0.7
0008:  CLRF   FEA
000A:  CLRF   FE9
000C:  BSF    FC1.0
000E:  BSF    FC1.1
0010:  BSF    FC1.2
0012:  BCF    FC1.3
0014:  CLRF   05
0016:  CLRF   06
0018:  MOVLW  55
001A:  MOVWF  05
001C:  MOVLW  AA
001E:  MOVWF  06
0020:  BRA    0020
0022:  SLEEP
