meme
PIC16F877-A ADC random values. |
Posted: Sun Aug 07, 2005 5:15 am |
I am using pic16f877A and on pin A1 I have a analog input. the code is:
Code: | #include "C:\Program Files\PICC\Termometru\termometru1.h"
#include <LCD.C>
#include <stdlib.h>
unsigned long val;
setup_adc_ports(AN0_AN1_VSS_VREF);
setup_psp(PSP_DISABLED);
set_adc_channel(1);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
delay_ms(200);
lcd_putc("Termometru...\n Asteptati...");
while(1){
delay_ms(2000);
val = read_adc();
printf(lcd_putc,"\fADC Val: %ld",val);
Termometru1.h is:
Code: | #include <16F877A.h>
#device adc=10
#fuses NOWDT,XT, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT |
on pin A1 I connected a 50K variable resistor (connected between the power supply 5V and ground).
Even if I don't modify the resistor I get strange results on my LCD: sometimes I get 1023 (the maximum value) sometimes I get 0. Also i get other values: 512, 640, 1 etc without modifying the resistor.
Any Ideas ?
thanks |
Humberto
Posted: Sun Aug 07, 2005 7:42 am |
Is expecting the Vrefh in PIN_A3. Are you getting the Vref HIGH to this pin ?
Check the possible constants used in SETUP_ADC_PORTS() in the 16F877A.H file.
Best wishes,
Humberto |
meme
Posted: Sun Aug 07, 2005 8:08 am |
that was it. thanks ! |
