		| View previous topic :: View next topic   |
			Markdem
				| I2C master\slave |
				 Posted: Sat Aug 06, 2005 5:59 am     |
				Hi All, after spending the last 4 hours on this fourm and google, i still do not understand what i am doing :(
All i want to do is turn on and off two LED every 2 seconds (this works)
I also want to display whether the LEDs are on or off on a LCD. I can write to the lcd, but my I2C code will not work. I have added a line to show when the slave starts the interrupt, but i never does.
Can somebody please, please help me...
Thank you
Mark
//Master
#include <16f877a.h>
#fuses NOWDT,HS, NOPROTECT, BROWNOUT, NOPUT, NODEBUG, NOLVP
#use i2c(MASTER, SDA=PIN_C4, SCL=PIN_C3, FORCE_HW)
int light1stat;
int light2stat;
         light1stat = 1;
   while(1){
      light1stat++;
      i2c_start();
      i2c_write(0xa0);
      i2c_write(light1stat);
      i2c_stop();
      output_low(PIN_D7);
      light2stat = 1;
        output_low(PIN_D6);
      light1stat = 0;
      output_high(PIN_D7);
      light1stat = 0;
      output_high(PIN_D6);
//slave
#include <marklcd420.c>
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, FORCE_HW, address=0xa0)
int light1stat;
int light2stat;
int count;
enable_interrupts(INT_SSP);
   count=1;
      printf(lcd_putc,"Ready");
      lcd_gotoxy(1,2);
      printf(lcd_putc,"Light1: %U",light1stat);
      lcd_gotoxy(1,3);
      printf(lcd_putc,"Light2: %U",light2stat);
      while(1){
#INT_SSP
void ssp_interupt ()
   count++;
   lcd_gotoxy(1,4);
   printf(lcd_putc,"Count: %U",count);
   i2c_start();
   light1stat = i2c_read();
   //light1stat = i2c_read();
   i2c_stop();
			Mark
				 Posted: Sat Aug 06, 2005 8:14 am     |
				| Look at the example programs.  Your slave receive is totally wrong.  There is an example slave program that will work for you. |
			Markdem
				 Posted: Sun Aug 07, 2005 12:59 am     |
				| I have spent the time looking at the example programs, both on the web and in the example folder in CCS, but i dont understand how they work. I need somthing "more" basic. Is the master code at least OK? |
			Markdem
				 Posted: Sun Aug 07, 2005 6:18 am     |
				| I have now tired some more debugging on this. My slave programe will never enter the interrupt part. Am i doing somthing wrong here?? |
			Mark
				 Posted: Sun Aug 07, 2005 6:59 am     |
				Look at ex_slave.c  That program is meant to emulate a serial eeprom.  It could be changed a bit to suit your needs.
I suspect that since you never enter the interrupt, maybe you forgot to add the pullups to the lines.
Also you might try this code out
http://www.ccsinfo.com/forum/viewtopic.php?t=21456 |
			Markdem
				 Posted: Sun Aug 14, 2005 3:16 am     |
				Hi All, after retring for a long time to get this working, i am so close, but yet so far.
When i run my new code, it works, but it will only run for a few seconds. After tht, both PIC will just stop. The LEDs on the master stop flashing, and my cound on the LCD on the master will stop. If i run the master without the slave, it will run OK. If i run the slave without the master, it is OK. the problem is only when two chips are on the bus at te same time.
I have looked at all the example programs, but they are all to complex for me and my project, so i cant use them. I just dont understand what they are doing.
The printf statments in the interrupt are only for debugging.
Can sombody please help
Thank you , mark
int light1stat;
int light2stat;
        i2c_start();
      i2c_write(0xa0);
      i2c_write(0x07);
      i2c_stop();
      output_low(PIN_D7);
      light2stat = 1;
        output_low(PIN_D6);
      light1stat = 0;
      light1stat = 0;
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0, FORCE_HW)
#use rs232(baud=9600,parity=N,bits=8,xmit=PIN_C6,rcv=PIN_C7)
#byte PIC_SSPBUF=0x13
#byte PIC_SSPADD=0x93
int isrcount;
char dummy;
int light1stat;
int count;
#INT_SSP
   dummy = i2c_read();
   printf("sspbuf=%Lx\r\n",PIC_SSPBUF);
   printf("sspadd=%Lx\r\n",PIC_SSPADD);
   printf("sspbuf2=%Lx\r\n",PIC_SSPBUF);
   printf("sspadd2=%Lx\r\n",PIC_SSPADD);
   isrcount++;
         light1stat = 0;
      lcd_gotoxy(1,1);
      lcd_gotoxy(1,2);
      printf(lcd_putc,"Light1: %S",light1stat);
      lcd_gotoxy(1,3);
      printf(lcd_putc,"dummy: %U",dummy);
      lcd_gotoxy(1,4);
       printf(lcd_putc,"ISR count: %U",isrcount);
       count++;
			ddscott
				 Posted: Tue Aug 23, 2005 9:01 am     |
				I don't know if you ever got a solution to your problem, but this is what I use to handle the i2c interrupt.  It seems to work as desired, I use an Aardvark I2C emulator to communicate with the slave PIC.
Hope this helps.
 	  | Code: | 	 		  include "C:\Program Files\PICC\Projects\Bio_Briefcase\i2c_0816.h"
int8 buffer;
boolean rec;
long j;
#int_SSP
void SSP_isr()
   if (i2c_poll() == TRUE)
      rec=true;
      buffer=i2c_read();
void check_int()
long j;
if (buffer == 0x11)
   rec = false;
   buffer = 0;
      for (j=0; j<10000; j++)
          output_toggle(pin_a1);
          delay_ms(1);
return;
   int8 data;
   long i;
   rec=false;
   buffer = 0;
   setup_timer_1(T1_DISABLED);
   setup_vref(VREF_LOW|-2);
   setup_oscillator(False);
   #priority ssp
   while (true) {
      data = buffer;
      rec=false;
      buffer = 0;
         if (data == 0x33)
             data = 0;
               for (i=0; i<30000; i++)
                     output_toggle(pin_a0);
                     delay_ms(1);
                        if (rec == true)
                           check_int();
			ella Guest
			ddscott
				| I2C emulators |
				 Posted: Wed Aug 24, 2005 10:28 am     |
				It should work just fine with any emulator.  Just be wary that the way PIC stores it's address might be different than how the emulator sends the address.  If I want my i2c emulator to talk to address 0x20, I need to set the PIC to respond to address 0x40.
I was able to get the PIC to write data to the emulator yesterday.  I monitor bit 2 in the SSPSTAT register.  When it is a 1, the master has sent a read cmd, and I jump to a routine that writes data.  Don't use i2c_start and i2c_stop instructions with the slave.
If you disable the interrupts to perform a high priority task, you need to reset the SSPCON register in software.  For the PIC I am using, 16f767, I load the register with 0x36.
Hope this helps. |
