uhohrobbo Guest
SPI 1 wire devices |
Posted: Fri Aug 05, 2005 4:19 am |
Hey,
I know that CCS C supports 2 and 3 wire SPI devices. Has anyone managed to get a 1 wire (or iButton) device to work with a non-1wire device (i.e. PIC18F248)?
Cheers |
Douglas Kennedy
Posted: Fri Aug 05, 2005 7:52 am |
Maybe you are asking can a PIC device act as a slave on a Dallas one wire (DOW) system.
Here is code I wrote a while back
The PIC takes on a DOW 8 byte unique identity via dev_id[8] it sends to a master ( there is CCS library code for a PIC to be a Master for the DOW see touch.c etc) upon a reset. The slave drops out if it is not being addressed
The reset pulses are triggered by a RC 33k 10nf that trips the interrupt on B0 the DOW line is driven by the PIC using the pin TOUCH_PIN
There is some reference to tokens ("T6063") where the pic would act as a DOW interface to say a T6963 LCD controller accepting data from a DOW master and displaying it on an LCD screen
The code is for the 16F84 so watch out for the register specific assignments.
Code: | /// drivers for dallas slave device emulation ////////////
//// electrical interface //////////
//// TOUCH_PIN should be open drain pulled up via 4.7K
//// to avoid loading dow when device id off
///// a high on the TOUCH_PIN switches the 2n7000 on ////////
///// holding cap 10nf at ground //////
//// a low on the TOUCH_PIN switches the 2n7000 off ////////
//// causing the 10nf cap to charge via R 33k ////////
//// after 10*nf*33k or 330us pin B0 is high ////////
//// any shorter time the voltage will not have risen enough /////
//// the next high on the dow (end of reset pulse ) /////
//// the 2n7000 conducts disharging the 10nf cap //////
//// In other words B0 goes from H to L on the rising edge at //////
//// completion of the reset pulse //////
//// diag //////
//// | Vdd +5V //////
//// R < 33K //////
//// |----------------------------->B0 //////
//// |-------__| D /////
//// | |_G________________TOUCHPIN /////
//// | __| | /////
//// | | | S 2n7000 | /////
/// C =====10nf | --- 5.6v /////
//// | | ^ zener /////
//// ^^^ ^^^ Vss (Gnd) ^^^ /////
// major code needs to set these
// #define TOUCH_PIN PIN_XX
//byte const dev_id[8]={0xFE,0x00,0x24,0xC6,0x50,0x00,0x00,0x97};
int dow_status;
#define slave_ready 1
#define slave_busy 2
#define master_ready 3
#define slave_not_ready 4
#define PCLATH 0x0A
#define PCL 0x02
#define INTF 1
//#define INTCON 0x0B
#define INTE 4
///////////////////////////////PROTOCOL /////////////////////////////////////
// slave fills transmit buff xmit_buff and sets dow_status to slave_ready
// if slave is ready master reads '{' data in buff '}' Ex {25C65} or{T6963}
// if slave is not ready master reads '!' and polls again
// if slave is busy processing a previous command
// an interrupt may cause it to hang
// Ex master interrupts a read of a previous command in progress
// leaving slave waiting for write slots
// a normal isr path would return the slave to the place it is reading
// only now the master has a new command probably causing the slave to hang
// to avoid returning to the point of interrupt a PC of 00 is jammed on the stack
// causing a complete CPU reset in otherwords a reboot of the slave
// when slave is busy doing things other than processing a master command
// ( Ex. monitoring the key board ) it sets the status to slave_not_ready
// the isr will send '!' back to master during match_rom polls allowing master
// to wait and repoll with a match_rom
// If master suspects the slave is hung a search_rom will reboot the slave
byte dow_read_byte() {
/// master goes low for less than 15us
/// after 30 us from beginning slave samples
/// if high we have 1 if low we have zero
byte i,data;
for(i=1;i<=8;++i) {
while (input(TOUCH_PIN) ); // wait till line goes low
// line is now low master will either release for a 1 or keep low for a 0
delay_us(30); // sample point
shift_right(&data,1,input(TOUCH_PIN));
while(!input(TOUCH_PIN)); // wait till line is high
return(data);
byte dow_write_byte(byte data) {
/// immediately slave goes low for an additional 15us to write 1
/// otherwise we allow line to float high
/// master samples within 5us of bringing the line low
byte i;
for(i=1;i<=8;++i)
while(input(TOUCH_PIN)); // wait for master to go low
if(shift_right(&data,1,0)) { output_float(TOUCH_PIN); }
else {
output_low(TOUCH_PIN);
delay_us(15);
delay_us(40);
return(TRUE);
#INLINE
void dow_presence() {
// master held line low for a least 240us and then goes high for 20 us
// slave sends presence pulse of a low of 100us
while(!input(TOUCH_PIN)); //wait until line is high
delay_us(20);
// presence
delay_us(100);
while(!input(TOUCH_PIN)); // wait for other devices to finish presence pulse
#INLINE
byte dow_search_rom()
byte i,j,this_byte;
short int this_bit;
// master has sent an 0xF0 search rom command
// master sends two read time slots
// we the slave send our true bit and then its inverse
// master then sends a select bit and if it matches we stay online
// for another cycle otherwise we go offline and wait for a reset pulse
for(j=0;j<=7;j++)
this_byte=dev_id[j];
for(i=1;i<=8;++i)
this_bit=shift_right(&this_byte,1,0); // note protocol ships LSbit first
// send true bit
// wait for low
while (input(TOUCH_PIN)) ;
// we now are seeing low
if(this_bit) {
} else {
//delay_us(15);
delay_us(20);
while(!input(TOUCH_PIN)); // wait until another device (if any) finishes writing 1
// send inverse bit
// wait for low
if(!this_bit) {
} else {
//delay_us(15);
delay_us(20);
// now see if master wants us if it does then it will write our bit
// read a bit
// wait for low
delay_us(20); // sample point
if(this_bit!=input(TOUCH_PIN)) return(FALSE);
while(!input(TOUCH_PIN) ); // wait till line goes high
}// i loop
}// j loop
return(TRUE);
#INLINE
byte dow_match_rom()
byte i,j,this_byte;
short int this_bit;
// master has sent an 0x55 match rom command
for (j=0;j<=7;j++)
for(i=1;i<=8;++i)
this_bit=shift_right(&this_byte,1,0); // note rs232 ships LSBit first
// read a bit
// wait for low
if(this_bit!=input(TOUCH_PIN)) return (FALSE);
}// of i loop
}// of j loop
return(TRUE);
int compcrc(char * string, int nbytes)
int crc,i,count;
char input;
crc=0;
for (i=0;i<nbytes;i++){
input=*(string+i);
#asm
movlw 8
movwf count
/* need to xor bit 0 of crc with next bit of input */
crc_loop:
movf crc,w
rrf input,f // rot right and save and next bit is in carry
btfsc status,carry
// need to know if xor result is a one or zero
// if carry is 0 then xor with zero = value of crc bit 0
// else carry is 1 xor with one = comp of crc bit 0
goto cbit_1
goto cbit_0
cbit_1:
// carry=input was 1
btfss crc,0
goto xor_bit1 // was 0 so complement to 1
goto xor_bit0 // was 1 so complement to 0
cbit_0:
// carry=input was 0
btfss crc,0
goto xor_bit0 // was 0
goto xor_bit1 // was 1
xor_bit1:
xorlw 0x18 // xors bits 4 and 5
movwf crc
rrf crc,f
bsf crc,7
goto loop_test
xor_bit0:
movwf crc
rrf crc,f
bcf crc,7
loop_test:
decfsz count,f
goto crc_loop
#endasm
return(crc);
#inline
void abort()
#asm
bcf INTCON,INTE /// turn off EXT_INT
bcf INTCON,INTF /// Clear the flag to avoid a repeat
clrf PCLATH /// clear high bits of progran counter
clrf PCL /// clear the low bits CPU will now restart
#endasm
#INT_EXT
void ext_int_isr()
byte cmd,i;
if (dow_status==slave_busy) abort(); /// not expecting an interrupt
/// master will have to reset again
/// after pausing to allow us to re-init
/// this clears up any glitches
dow_presence();
cmd=dow_read_byte();
if (cmd==0xF0) { //search rom
if (!dow_search_rom()) goto quit;
if(dow_status==slave_not_ready) abort(); // slave was hung up
goto quit; // we are selected but will wait for a 0x55
if (cmd==0x55){ // match rom
if (!dow_match_rom()) goto quit;
// we are now selected and wait for master to read
if (dow_status==slave_ready)
#ifdef LED1
output_high(LED1);
dow_write_byte('{');
// send out id sentence of Eg.T6963
for(i=0;i<=7;i++)
if (dev_name[i]==0) break; // null terminated
dow_write_byte(dev_name[i]);
dow_write_byte('}');
#ifdef BUFF_SIZE
for(i=0;i<BUFF_SIZE;i++) dow_write_byte(xmit_buff[i]);
#ifdef LED1
output_low(LED1);
dow_status=master_ready; // master next will send commands
else dow_write_byte('!');// slave is not ready master will have to wait
// for slave to assert status slave_ready
// or send FO to reset
quit:
Douglas Kennedy
Posted: Fri Aug 05, 2005 7:53 am |
Duplicate posting |
