| Poniter to const, is there a work around? |
Posted: Tue Jul 26, 2005 7:12 pm |
I'm attemping to use the PIC18 and have calibrations in ROM and want to access them via a pointer in memory.
Thanks for your help |
valemike Guest
Posted: Tue Jul 26, 2005 8:50 pm |
Look at this FAQ:
http://www.ccsinfo.com/faq/?19
| Quote: |
How can a constant data table be placed in ROM?
The compiler has support for placing any data structure into the device ROM as a constant read-only element. Since the ROM and RAM data paths are separate in the PIC, there are restrictions on how the data is accessed. For example, to place a 10 element BYTE array in ROM use:
BYTE CONST TABLE [10]= {9,8,7,6,5,4,3,2,1,0};
and to access the table use:
x = TABLE [i];
OR
x = TABLE [5];
BUT NOT
ptr = &TABLE [i];
In this case, a pointer to the table cannot be constructed.
Similar constructs using CONST may be used with any data type including structures, longs and floats.
Posted: Wed Jul 27, 2005 2:22 am |
There are however 'semi workrounds', depending on the chip involved. The simplest, is to not use the const declaration, but instead use the #ROM declaration, and put the block of data at a fixed location in ROM memory, that you save and control. Perhaps the last 256 bytes in a typical system not using ICD. The contents of this block can then be accessed using 'read_program_eeprom' (provided the chip is a 'flash' part, offering this ability).
The alternative, is that the 'label_address' function will return the address in ROM, where a constant is stored, and again this can be used with read_program_eeprom to access the data. This however carries a 'caveat', that normally the data is stored with a 'retrieval header', which contains the code to allow it to be accessed, so the real data is a few bytes latter in the memory.
Chips without read_program_eeprom, cannot really be accessed except by the array method, because on these, the locations do not actually contain the required data, but 'retlw' instructions setup to return the value.
