Codeloader: Increase MAX_LOADABLE value.
sshon
PostPosted: Sun Jul 24, 2005 10:03 pm     Reply with quote
I'm using Codeloader on a PIC18F6720 chip. When I change the MAX_LOADABLE value from 0x6800 to 0x10000, the compiler shows "Invalid ORG range" error. The maxumim value I can set for MAX_LOADABLE is only up to 0xFFFF. I'm using PCH v3.228. Anyone has the same problem?
PostPosted: Sun Jul 24, 2005 11:25 pm     Reply with quote
I think you can work-around this problem by using
two #org statements. The first #org reserves ROM
in the lower 64K, and the 2nd #org statement handles
the upper 64K region.
#if getenv("FUSE_SET:WDT")==TRUE
#define MAX_LOADABLE   0x1E800
#else
#define MAX_LOADABLE   0x1E820
#org 0x0008, 0xFFFF {}
#org 0x10000, MAX_LOADABLE {}
sshon
sshon
PostPosted: Sun Jul 24, 2005 11:51 pm     Reply with quote
Problem solved with the work-around. Thank you very much Smile
