Tiny Bootloader
Kieran
Tiny Bootloader
PostPosted: Sun Jul 17, 2005 4:28 am     Reply with quote
Has anybody ported this loader to a large memory PIC such as 18F6720?
I'm not very good at PIC assembler (all CCS's fault :) ) but I think the code is limited to a 16 bit address i.e. 64k code size.
Also the watchdog has to be dissabled which limits it's use.
Has anybody done a watchdog enabled version?
The realy attractive feature is it's size.
asmallri
PostPosted: Sun Jul 17, 2005 8:39 am     Reply with quote
I have not ported the code but most of the smarts are in the programming application not the loader itself.
Regards, Andrew
Mark
PostPosted: Sun Jul 17, 2005 8:54 am     Reply with quote
PIC18's allow you to control the watchdog (on/off) so how does that limit you?
Kieran
PostPosted: Sun Jul 17, 2005 1:25 pm     Reply with quote
Don't understand the reply Embarassed
Still say that the Tiny boot loader won't handle PIC18F6720
Thanks mark. You are right I missed that
asmallri
PostPosted: Sun Jul 17, 2005 6:11 pm     Reply with quote
My point was the port to the PIC18F6720 (code in the PIC) will be minor but you will have to modify the PC application to support different PICs that the application does not natively support.
Regards, Andrew
bb
PostPosted: Mon Jul 18, 2005 2:13 pm     Reply with quote
Hi Kieran,
what version are you using? I've informed Claudiu of a bug introduced in V1.6 (which was still present at V1.7) regarding PICs with more than 64k of flash memory. This bug was located in the PC application. I've done some testing for him and V1.73 onwards works for me without any problems (18F8720/18F8722).
1.73(Apr.2005)
- RTS pulse option
- Abort btn.
- fixed bugs for large memory PICs (like 8720)
- more detailed logging
- fix for 2620
Best regards,
Bernd
Kieran
PostPosted: Sat Jul 23, 2005 7:07 am     Reply with quote
Sorry for the delay in replying, I have only just got back to looking at this.
I have version 1.8 of the PC app.
This reports that it has found
18F 6720/8720
then
Could not write ERROR!
Any ideas what I could be doing wrong?
Humberto
PostPosted: Sat Jul 23, 2005 9:52 pm     Reply with quote
The following link address you to the Colt PIC18F Bootloader wich support most of the 18F PICs.
It has all the instructions and directives to relocate user code using CCS compiler.
http://mdubuc.freeshell.org/Colt/
Hope this help you,
Humberto
Kieran
PostPosted: Mon Jul 25, 2005 12:13 pm     Reply with quote
Thanks Humberto
Interesting but not as small as the Tiny Bootloader and requires a port pin to control the loader which I don't have access to.
mot_ala
bootloader
PostPosted: Tue Jun 19, 2007 7:40 am     Reply with quote
how to use boot loader to update firmware over the air
