Guard
LCD character pattern |
Posted: Thu Mar 17, 2005 8:07 am |
Do you know code for write character pattern on lcd?
Thanks |
ljbeng
Posted: Thu Mar 17, 2005 8:30 am |
A character is sent to the lcd with RS line held high.
Commands are send the same way with RS held low.
To do custom characters, you need to define the bit pattern with 8 byte values:
Code: | BYTE const lcd_custom[8] = {
0x1f,0x11,0x0a,4,0x0a,0x11,0x1f,0, //;picture of hour glass
First, initialize the lcd like normal.
Next you need to send 8 bytes to the lcd with RS held low. Be sure to send 8 bytes for each custom character. Each byte maps which squares are on or off for a single line of the 5 x 8 character block. |
nibble
Posted: Wed Jul 20, 2005 12:19 pm |
Hi
How can i read character pattern from CGram? |
Mark
Posted: Wed Jul 20, 2005 6:03 pm |
Read that RAM address. |
treitmey
I am nibble Guest
Posted: Thu Jul 21, 2005 11:50 am |
I am using alphanumeric LCD.
I put rs to 0 and write to 0x40 for CGRAM address
then I put rs to 1 and write the chr pattern. ( 8 byte)
How read the ddram?
Thank |
I am nibble Guest
Posted: Thu Jul 21, 2005 12:08 pm |
I don't use R/W pin |
Mark
Posted: Thu Jul 21, 2005 2:26 pm |
R/W
R = Read
W = Write
See if you can figure it out |
