MD5 Calculation with PIC16F877A
rpweis
PostPosted: Tue Jul 19, 2005 2:47 pm     Reply with quote
I was trying to write an MD5 routine using the MD5 specification (rfc1321) and I ran out of ROM. Has anyone written a simpler version or done this another way? Basically I have to produce an MD5 of the contents of program memory (all of it) on request at any time for security purposes and I'm trying to do it within the pic as opposed to having dedicated external hardware. As far as an external implementation goes,
dsPIC with microchips encryption library looks like it would be a good approach. Anyone have any experience with dedicated security processors (usually seen in the secure networking market)?
Thanks,
Rob
treitmey
PostPosted: Wed Jul 20, 2005 7:37 am     Reply with quote
Do you have the *=16 in your code. Try and recompile with this in.
#include <16f877.h>
#device *=16
rpweis
PostPosted: Wed Jul 20, 2005 9:04 am     Reply with quote
Yes I do have that in my code. I used reference parameters and the compiler directive "#separate" and all the other tricks I know of to try and make it fit. The compiler is not actually out of ROM, just doesn't have a block big enough left.
-Rob
treitmey
PostPosted: Wed Jul 20, 2005 10:27 am     Reply with quote
In your/my tricks, I will sometimes, "TELL" the compiler where the BIG block should go, then let it fill in the little spots. Can you post the code?
#include <16F877.h>
#device *=16
#use delay(clock=16000000)
#fuses HS,NOWDT,NOLVP,
#use rs232(baud=19200,xmit=PIN_C4,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#case
#zero_ram
#RESERVE  0x110:0x17F
int8 buffer[112];//bigest size of block in 16F877 16+80+16=112
#BYTE buffer=0x110
//======================= Main ==============================
  int8 i;
  fprintf(DEBUG,"Starting\n\r");
  for (i=0;i<112;i++)
    buffer[i]=i;
    fprintf(DEBUG,"%u\n\r",buffer[i]);
rpweis
PostPosted: Wed Jul 20, 2005 11:32 am     Reply with quote
Ok, here's my code. It's a little long b/c the include wasn't getting along earlier, probably works now but it doesn't really matter.
#device PIC16F877A *=16
#fuses HS,NOWDT,NOPUT,NODEBUG,NOPROTECT,NOBROWNOUT,NOLVP,NOCPD,NOWRT
typedef int byte;
#include <stdio.h>
#include <math.h>
#use STANDARD_IO(A)
#use STANDARD_IO(B)
#use STANDARD_IO(C)
#use STANDARD_IO(D)
#use STANDARD_IO(E)
#define PIN_A0  40
#define PIN_A1  41
#define PIN_A2  42
#define PIN_A3  43
#define PIN_A4  44
#define PIN_A5  45
#define PIN_B0  48
#define PIN_B1  49
#define PIN_B2  50
#define PIN_B3  51
#define PIN_B4  52
#define PIN_B5  53
#define PIN_B6  54
#define PIN_B7  55
#define PIN_C0  56
#define PIN_C1  57
#define PIN_C2  58
#define PIN_C3  59
#define PIN_C4  60
#define PIN_C5  61
#define PIN_C6  62
#define PIN_C7  63
#define PIN_D0  64
#define PIN_D1  65
#define PIN_D2  66
#define PIN_D3  67
#define PIN_D4  68
#define PIN_D5  69
#define PIN_D6  70
#define PIN_D7  71
#define PIN_E0  72
#define PIN_E1  73
#define PIN_E2  74
#BIT RCIF = 0x0C.5
////////////////////////////////////////////////////////////////// CCP
// CCP Functions: SETUP_CCPx, SET_PWMx_DUTY
// CCP Variables: CCP_x, CCP_x_LOW, CCP_x_HIGH
// Constants used for SETUP_CCPx() are:
#define CCP_OFF                         0
////////////////////////////////////////////////////////////////// PSP
// PSP Functions: SETUP_PSP, PSP_INPUT_FULL(), PSP_OUTPUT_FULL(),
//                PSP_OVERFLOW(), INPUT_D(), OUTPUT_D()
// PSP Variables: PSP_DATA
// Constants used in SETUP_PSP() are:
#define PSP_ENABLED                     0x10
#define PSP_DISABLED                    0
////////////////////////////////////////////////////////////////// UART
// Constants used in setup_uart() are:
// FALSE - Turn UART off
// TRUE  - Turn UART on
#define UART_ADDRESS 2
#define UART_DATA    4
////////////////////////////////////////////////////////////////// COMP
// Comparator Variables: C1OUT, C2OUT
// Constants used in setup_comparators() are:
#define A0_A3_A1_A3  0xfff04
#define A0_A3_A1_A2_OUT_ON_A4_A5  0xfcf03
#define A0_A3_A1_A3_OUT_ON_A4_A5  0xbcf05
#define NC_NC_NC_NC  0x0ff07
#define A0_A3_A1_A2  0xfff02
#define A0_A3_NC_NC_OUT_ON_A4  0x9ef01
#define A0_VR_A1_VR 0x3ff06
#define A3_VR_A2_VR 0xcff0e
#bit C1OUT = 0x9c.6
#bit C2OUT = 0x9c.7
////////////////////////////////////////////////////////////////// Timer 0
// Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER0(),
//                              SET_TIMER0() or SET_RTCC(),
//                              GET_TIMER0() or GET_RTCC()
// Constants used for SETUP_TIMER0() are:
#define RTCC_INTERNAL   0
#define RTCC_EXT_L_TO_H 32
#define RTCC_EXT_H_TO_L 48
#define RTCC_DIV_1      8
#define RTCC_DIV_2      0
#define RTCC_DIV_4      1
#define RTCC_DIV_8      2
#define RTCC_DIV_16     3
#define RTCC_DIV_32     4
#define RTCC_DIV_64     5
#define RTCC_DIV_128    6
#define RTCC_DIV_256    7
#define RTCC_8_BIT      0
// Constants used for SETUP_COUNTERS() are the above
// constants for the 1st param and the following for
// the 2nd param:
////////////////////////////////////////////////////////////////// WDT
// Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
//                            RESTART_WDT()
#define WDT_18MS        8
#define WDT_36MS        9
#define WDT_72MS       10
#define WDT_144MS      11
#define WDT_288MS      12
#define WDT_576MS      13
#define WDT_1152MS     14
#define WDT_2304MS     15
////////////////////////////////////////////////////////////////// Timer 1
// Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
// Constants used for SETUP_TIMER_1() are:
//      (or (via |) together constants from each group)
#define T1_DISABLED         0
#define T1_INTERNAL         0x85
#define T1_EXTERNAL         0x87
#define T1_EXTERNAL_SYNC    0x83
#define T1_CLK_OUT          8
#define T1_DIV_BY_1         0
#define T1_DIV_BY_2         0x10
#define T1_DIV_BY_4         0x20
#define T1_DIV_BY_8         0x30
////////////////////////////////////////////////////////////////// Timer 2
// Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
// Constants used for SETUP_TIMER_2() are:
#define T2_DISABLED         0
#define T2_DIV_BY_1         4
#define T2_DIV_BY_4         5
#define T2_DIV_BY_16        6
////////////////////////////////////////////////////////////////// VREF
// Constants used in setup_vref() are:
#define VREF_LOW  0xa0
#define VREF_HIGH 0x80
#define VREF_A2   0x40
////////////////////////////////////////////////////////////////// ADC
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
//                SET_ADC_CHANNEL(), READ_ADC()
// Constants used in SETUP_ADC_PORTS() are:
#define NO_ANALOGS             0x86         // None
#define ALL_ANALOG             0x80         // A0 A1 A2 A3 A5 E0 E1 E2 Ref=Vdd
#define ANALOG_RA3_REF         0x81         // A0 A1 A2 A5 E0 E1 E2 Ref=A3
#define A_ANALOG               0x82         // A0 A1 A2 A3 A5 Ref=Vdd
#define A_ANALOG_RA3_REF       0x83         // A0 A1 A2 A5 Ref=A3
#define RA0_RA1_RA3_ANALOG     0x84         // A0 A1 A3 Ref=Vdd
#define RA0_RA1_ANALOG_RA3_REF 0x85         // A0 A1 Ref=A3
#define ANALOG_RA3_RA2_REF              0x88   // A0 A1 A5 E0 E1 E2 Ref=A2,A3
#define ANALOG_NOT_RE1_RE2              0x89   // A0 A1 A2 A3 A5 E0 Ref=Vdd
#define ANALOG_NOT_RE1_RE2_REF_RA3      0x8A   // A0 A1 A2 A5 E0 Ref=A3
#define ANALOG_NOT_RE1_RE2_REF_RA3_RA2  0x8B   // A0 A1 A5 E0 Ref=A2,A3
#define A_ANALOG_RA3_RA2_REF            0x8C   // A0 A1 A5 Ref=A2,A3
#define RA0_RA1_ANALOG_RA3_RA2_REF      0x8D   // A0 A1 Ref=A2,A3
#define RA0_ANALOG                      0x8E   // A0
#define RA0_ANALOG_RA3_RA2_REF          0x8F   // A0 Ref=A2,A3
// Constants used for SETUP_ADC() are:
#define ADC_OFF                0              // ADC Off
#define ADC_CLOCK_DIV_2        1
#define ADC_CLOCK_DIV_8     0x41
#define ADC_CLOCK_DIV_32    0x81
#define ADC_CLOCK_INTERNAL  0xc1              // Internal 2-6us
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ     7   // This is the default if nothing is specified
#define ADC_START_ONLY         1
#define ADC_READ_ONLY          6
////////////////////////////////////////////////////////////////// INT
// Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
//                      EXT_INT_EDGE()
// Constants used in EXT_INT_EDGE() are:
#define L_TO_H              0x40
#define H_TO_L                 0
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL                    0x0BC0
#define INT_RTCC                  0x0B20
#define INT_RB                    0x0B08
#define INT_EXT                   0x0B10
#define INT_AD                    0x8C40
#define INT_TBE                   0x8C10
#define INT_RDA                   0x8C20
#define INT_TIMER1                0x8C01
#define INT_TIMER2                0x8C02
#define INT_CCP1                  0x8C04
#define INT_CCP2                  0x8D01
#define INT_SSP                   0x8C08
#define INT_PSP                   0x8C80
#define INT_BUSCOL                0x8D08
#define INT_EEPROM                0x8D10
#define INT_TIMER0                0x0B20
#define INT_COMP                  0x8D40
//#BIT RCIF = 0x0C.5
//#define vmax 7800
//#define accel 160
//#define decel 240
#define md5length 115200
int32 workmssg[16];
#use rs232(baud=9600, xmit=PIN_C6, RCV=PIN_C7, PARITY=E, ERRORS)
int32 f(int32 x,int32 y, int32 z);
int32 g(int32 x,int32 y, int32 z);
int32 h(int32 x,int32 y, int32 z);
int32 i(int32 x,int32 y, int32 z);
int32 ff(int32 a,int32 b, int32 c, int32 d, int k, int s, int i);
int32 gg(int32 a,int32 b, int32 c, int32 d, int k, int s, int i);
int32 hh(int32 a,int32 b, int32 c, int32 d, int k, int s, int t);
int32 ii(int32 a,int32 b, int32 c, int32 d, int k, int s, int t);
#separate
   int32 res;
   res = (((x)&(y))|((~x)&(z)));
   return(res);
#separate
   int32 res;
   res = (((x)&(z))|((y)&(~z)));
   return(res);
#separate
   int32 res;
   res = ((x)^(y)^(z));
   return(res);
#separate
   int32 res;
   res = ((y)^((x)|(~z)));
   return(res);
#separate
int32 ff(int32 a,int32 b, int32 c, int32 d, int k, int s, int i)   //round 1 function
     /* Let [abcd k s i] denote the operation
          a = b + ((a + F(b,c,d) + X[k] + T[i]) <<< s). */
   int32 res;
   res = b+(a+f(b,c,d)+workmssg[k]+(4294967296*abs(sin(i))));
   res = (((res)<<(s))|((res)>>(32-(s)))); //rotate left
   return(res);
#separate
int32 gg(int32 a,int32 b, int32 c, int32 d, int k, int s, int i)   //round 2 function
          a = b + ((a + G(b,c,d) + X[k] + T[i]) <<< s). */
   int32 res;
   res = b + (a+g(b,c,d) + workmssg[k] + (4294967296*abs(sin(i))));
   return(res);
#separate
int32 hh(int32 a,int32 b, int32 c, int32 d, int k, int s, int t)   //round 3 function
     /* Let [abcd k s t] denote the operation
          a = b + ((a + H(b,c,d) + X[k] + T[i]) <<< s). */
   int32 res;
   res = b + (a + h(b,c,d) + workmssg[k] + (4294967296*abs(sin(t))));
   return(res);
#separate
int32 ii(int32 a,int32 b, int32 c, int32 d, int k, int s, int t)   //round 4 function
          a = b + ((a + I(b,c,d) + X[k] + T[i]) <<< s). */
   int32 res;
   res = b + (a + i(b,c,d) + workmssg[k] + (4294967296*abs(sin(t))));
   return(res);
#separate
void round1a(int32& a,int32& b,int32& c,int32& d)
      /* Round 1. */
    /* Do the following 16 operations. */
   /*   [ABCD  0  7  1]  [DABC  1 12  2]  [CDAB  2 17  3]  [BCDA  3 22  4]
       [ABCD  4  7  5]  [DABC  5 12  6]  [CDAB  6 17  7]  [BCDA  7 22  8]
         [ABCD  8  7  9]  [DABC  9 12 10]  [CDAB 10 17 11]  [BCDA 11 22 12]
        [ABCD 12  7 13]  [DABC 13 12 14]  [CDAB 14 17 15]  [BCDA 15 22 16]*/
   a = ff(a,b,c,d,0,7,1);
   d = ff(d,a,b,c,1,12,2);
   c = ff(c,d,a,b,2,17,3);
   b = ff(b,c,d,a,3,22,4);
#separate
void round1b(int32& a,int32& b,int32& c,int32& d)
   a = ff(a,b,c,d,4,7,5);
   d = ff(d,a,b,c,5,12,6);
   c = ff(c,d,a,b,6,17,7);
   b = ff(b,c,d,a,7,22,8);
#separate
void round1c(int32& a,int32& b,int32& c,int32& d)
   a = ff(a,b,c,d,8,7,9);
   d = ff(d,a,b,c,9,12,10);
   c = ff(c,d,a,b,10,17,11);
   b = ff(b,c,d,a,11,22,12);
#separate
void round1d(int32& a,int32& b,int32& c,int32& d)
   a = ff(a,b,c,d,12,7,13);
   d = ff(d,a,b,c,13,12,14);
   c = ff(c,d,a,b,14,17,15);
   b = ff(b,c,d,a,15,22,16);
#separate
void round2a(int32& a,int32& b,int32& c,int32& d)
    /* Round 2. */
   /*   [ABCD  1  5 17]  [DABC  6  9 18]  [CDAB 11 14 19]  [BCDA  0 20 20]
      [ABCD  5  5 21]  [DABC 10  9 22]  [CDAB 15 14 23]  [BCDA  4 20 24]
      [ABCD  9  5 25]  [DABC 14  9 26]  [CDAB  3 14 27]  [BCDA  8 20 28]
      [ABCD 13  5 29]  [DABC  2  9 30]  [CDAB  7 14 31]  [BCDA 12 20 32]*/
   a = gg(a,b,c,d,1,5,17);
   d = gg(d,a,b,c,6,9,18);
   c = gg(c,d,a,b,11,14,19);
   b = gg(b,c,d,a,0,20,20);
#separate
void round2b(int32& a,int32& b,int32& c,int32& d)
   a = gg(a,b,c,d,5,5,21);
   d = gg(d,a,b,c,10,9,22);
   b = gg(b,c,d,a,4,20,24);
#separate
void round2c(int32& a,int32& b,int32& c,int32& d)
   a = gg(a,b,c,d,9,5,25);
   d = gg(d,a,b,c,14,9,26);
   c = gg(c,d,a,b,3,14,27);
   b = gg(b,c,d,a,8,20,28);
#separate
void round2d(int32& a,int32& b,int32& c,int32& d)
   a = gg(a,b,c,d,13,5,29);
   d = gg(d,a,b,c,2,9,30);
   c = gg(c,d,a,b,7,14,31);
   b = gg(b,c,d,a,12,20,32);
#separate
void round3a(int32& a,int32& b,int32& c,int32& d)
   /* Round 3. */
   /*   [ABCD  5  4 33]  [DABC  8 11 34]  [CDAB 11 16 35]  [BCDA 14 23 36]
      [ABCD  1  4 37]  [DABC  4 11 38]  [CDAB  7 16 39]  [BCDA 10 23 40]
      [ABCD 13  4 41]  [DABC  0 11 42]  [CDAB  3 16 43]  [BCDA  6 23 44]
      [ABCD  9  4 45]  [DABC 12 11 46]  [CDAB 15 16 47]  [BCDA  2 23 48]*/
   a = hh(a,b,c,d,5,4,33);
   d = hh(d,a,b,c,8,11,34);
   c = hh(c,d,a,b,11,16,35);
   b = hh(b,c,d,a,14,23,36);
#separate
void round3b(int32& a,int32& b,int32& c,int32& d)
   a = hh(a,b,c,d,1,4,37);
   d = hh(d,a,b,c,4,11,38);
   c = hh(c,d,a,b,7,16,39);
   b = hh(b,c,d,a,10,23,40);
#separate
void round3c(int32& a,int32& b,int32& c,int32& d)
   a = hh(a,b,c,d,13,4,41);
   d = hh(d,a,b,c,0,11,42);
   c = hh(c,d,a,b,3,16,43);
   b = hh(b,c,d,a,6,23,44);
#separate
void round3d(int32& a,int32& b,int32& c,int32& d)
   a = hh(a,b,c,d,9,4,45);
   d = hh(d,a,b,c,12,11,46);
   c = hh(c,d,a,b,15,16,47);
   b = hh(b,c,d,a,2,23,48);
#separate
void round4a(int32& a,int32& b,int32& c,int32& d)
#separate
void round4b(int32& a,int32& b,int32& c,int32& d)
#separate
void round4c(int32& a,int32& b,int32& c,int32& d)
#separate
void round4d(int32& a,int32& b,int32& c,int32& d)
   int i,j;
   int32 extmssg[16],aa,bb,cc,dd,a,b,c,d;
   for(i=0;i<16;i++)
      extmssg[i]=0;
   extmssg[0] = 1;
   extmssg[14] = md5length;
   a = 0x01234567;
   b = 0x89abcdef;
   c = 0xfedcba98;
   d = 0x76543210;
   for(i=0;i<=((md5length/32)/16-2);i++)   //-2 b/c of goofy extmssg idea
      for(j=0;j<=15;j++)
         workmssg[j] = read_program_eeprom((i*16)+j);
      aa=a;
      bb=b;
      cc=c;
      dd=d;
      round1a(a,b,c,d);
      round1b(a,b,c,d);
      round1c(a,b,c,d);
      round1d(a,b,c,d);
      round2a(a,b,c,d);
      round2b(a,b,c,d);
      round2c(a,b,c,d);
      round2d(a,b,c,d);
      round3a(a,b,c,d);
      round3b(a,b,c,d);
      round3c(a,b,c,d);
      round3d(a,b,c,d);
      round4a(a,b,c,d);
      round4b(a,b,c,d);
      round4c(a,b,c,d);
      round4d(a,b,c,d);
      a += aa;
      b += bb;
      c += cc;
      d += dd;
   //md5 done, result is DCBA
The reason there are so many functions is because I was trying to make the smallest blocks possible for the compiler to place. I made them all separate to force it to call instead of place it inline. The 32 bit math is definately killer on the RAM, but I thought that a PIC should be able to calculate an MD5 hash. The math isn't that bad, just big numbers. Any thoughts?
Thanks,
Rob
rpweis
typedef int byte;
#include <stdio.h>
#include <math.h>
#use STANDARD_IO(A)
#use STANDARD_IO(B)
#use STANDARD_IO(C)
#use STANDARD_IO(D)
#use STANDARD_IO(E)
#define PIN_A0  40
#define PIN_A1  41
#define PIN_A2  42
#define PIN_A3  43
#define PIN_A4  44
#define PIN_A5  45
#define PIN_B0  48
#define PIN_B1  49
#define PIN_B2  50
#define PIN_B3  51
#define PIN_B4  52
#define PIN_B5  53
#define PIN_B6  54
#define PIN_B7  55
#define PIN_C0  56
#define PIN_C1  57
#define PIN_C2  58
#define PIN_C3  59
#define PIN_C4  60
#define PIN_C5  61
#define PIN_C6  62
#define PIN_C7  63
#define PIN_D0  64
#define PIN_D1  65
#define PIN_D2  66
#define PIN_D3  67
#define PIN_D4  68
#define PIN_D5  69
#define PIN_D6  70
#define PIN_D7  71
#define PIN_E0  72
#define PIN_E1  73
#define PIN_E2  74
#BIT RCIF = 0x0C.5
#define CCP_OFF                         0
#define UART_DATA    4
#bit C1OUT = 0x9c.6
#bit C2OUT = 0x9c.7
// the 2nd param:
//                            RESTART_WDT()
#define WDT_18MS        8
#define WDT_36MS        9
#define WDT_72MS       10
//                      EXT_INT_EDGE()
#define L_TO_H              0x40
#define H_TO_L                 0
//#define vmax 7800
//#define accel 160
//#define decel 240
int32 workmssg[16];
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
      /* Round 1. */
#separate
#separate
#separate
#separate
    /* Round 2. */
#separate
#separate
#separate
#separate
   /* Round 3. */
#separate
#separate
#separate
#separate
#separate
#separate
#separate
   int i,j;
   for(i=0;i<16;i++)
      extmssg[i]=0;
   extmssg[0] = 1;
   a = 0x01234567;
   b = 0x89abcdef;
   c = 0xfedcba98;
   d = 0x76543210;
      for(j=0;j<=15;j++)
      aa=a;
      bb=b;
      cc=c;
      dd=d;
      round1a(a,b,c,d);
      round1b(a,b,c,d);
      round1c(a,b,c,d);
      round1d(a,b,c,d);
      round2a(a,b,c,d);
      round2b(a,b,c,d);
      round2c(a,b,c,d);
      round2d(a,b,c,d);
      round3a(a,b,c,d);
      round3b(a,b,c,d);
      round3c(a,b,c,d);
      round3d(a,b,c,d);
      round4a(a,b,c,d);
      round4b(a,b,c,d);
      round4c(a,b,c,d);
      round4d(a,b,c,d);
      a += aa;
      b += bb;
      c += cc;
      d += dd;
Thanks,
Rob
rpweis
PostPosted: Wed Jul 20, 2005 11:33 am     Reply with quote
typedef int byte;
#include <stdio.h>
#include <math.h>
#use STANDARD_IO(A)
#use STANDARD_IO(B)
#use STANDARD_IO(C)
#use STANDARD_IO(D)
#use STANDARD_IO(E)
#define PIN_A0  40
#define PIN_A1  41
#define PIN_A2  42
#define PIN_A3  43
#define PIN_A4  44
#define PIN_A5  45
#define PIN_B0  48
#define PIN_B1  49
#define PIN_B2  50
#define PIN_B3  51
#define PIN_B4  52
#define PIN_B5  53
#define PIN_B6  54
#define PIN_B7  55
#define PIN_C0  56
#define PIN_C1  57
#define PIN_C2  58
#define PIN_C3  59
#define PIN_C4  60
#define PIN_C5  61
#define PIN_C6  62
#define PIN_C7  63
#define PIN_D0  64
#define PIN_D1  65
#define PIN_D2  66
#define PIN_D3  67
#define PIN_D4  68
#define PIN_D5  69
#define PIN_D6  70
#define PIN_D7  71
#define PIN_E0  72
#define PIN_E1  73
#define PIN_E2  74
#BIT RCIF = 0x0C.5
#define CCP_OFF                         0
#define UART_DATA    4
#bit C1OUT = 0x9c.6
#bit C2OUT = 0x9c.7
// the 2nd param:
//                            RESTART_WDT()
#define WDT_18MS        8
#define WDT_36MS        9
#define WDT_72MS       10
//                      EXT_INT_EDGE()
#define L_TO_H              0x40
#define H_TO_L                 0
//#define vmax 7800
//#define accel 160
//#define decel 240
int32 workmssg[16];
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
   int32 res;
   return(res);
#separate
      /* Round 1. */
#separate
#separate
#separate
#separate
    /* Round 2. */
#separate
#separate
#separate
#separate
   /* Round 3. */
#separate
#separate
#separate
#separate
#separate
#separate
#separate
   int i,j;
   for(i=0;i<16;i++)
      extmssg[i]=0;
   extmssg[0] = 1;
   a = 0x01234567;
   b = 0x89abcdef;
   c = 0xfedcba98;
   d = 0x76543210;
      for(j=0;j<=15;j++)
      aa=a;
      bb=b;
      cc=c;
      dd=d;
      round1a(a,b,c,d);
      round1b(a,b,c,d);
      round1c(a,b,c,d);
      round1d(a,b,c,d);
      round2a(a,b,c,d);
      round2b(a,b,c,d);
      round2c(a,b,c,d);
      round2d(a,b,c,d);
      round3a(a,b,c,d);
      round3b(a,b,c,d);
      round3c(a,b,c,d);
      round3d(a,b,c,d);
      round4a(a,b,c,d);
      round4b(a,b,c,d);
      round4c(a,b,c,d);
      round4d(a,b,c,d);
      a += aa;
      b += bb;
      c += cc;
      d += dd;
Thanks,
Rob
rpweis
PostPosted: Wed Jul 20, 2005 11:34 am     Reply with quote
Sorry about the multiple posts, the page kept saying it couldn;t load, but apparently it did.
-Rob
newguy
PostPosted: Wed Jul 20, 2005 1:14 pm     Reply with quote
Since you were logged in when you posted, you can delete the extra posts. Just click the X in the box when you view the post(s).
PostPosted: Wed Jul 20, 2005 1:24 pm     Reply with quote
You can only delete a post if it's the last one added to the thread.
Once someone replies to it, the little "X" box is no longer available.
But you can still edit your duplicate posts and delete the text in them.
treitmey
PostPosted: Wed Jul 20, 2005 3:51 pm     Reply with quote
I can't find a way to make your program fit in ROM.
The program is just too big.
When I comment out functions, I can leave in like 3 and it compiles.
at about 50% ram 50% rom.
Add another function call and it blows. ??? Anyone know why such a big jump.
#include <16F877A.h>
#device *=16
#use delay(clock=6000000)
#fuses HS,NOWDT,NOLVP,PROTECT,PUT,BROWNOUT
#use rs232(baud=19200,xmit=PIN_E0,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#use rs232(baud=1200,errors,xmit=PIN_C6,rcv=PIN_C7,parity=e,enable=PIN_C5,bits=8,stream=CIM)
#include <stdio.h>
#include <math.h>
#use STANDARD_IO(A)
#use STANDARD_IO(B)
#use STANDARD_IO(C)
#use STANDARD_IO(D)
#use STANDARD_IO(E)
#BIT RCIF = 0x0C.5
#bit C1OUT = 0x9c.6
#bit C2OUT = 0x9c.7
int32 workmssg[16];
//#use rs232(baud=9600, xmit=PIN_C6, RCV=PIN_C7, PARITY=E, ERRORS)
   int32 res;
   return(res);
   int32 res;
   return(res);
   int32 res;
   return(res);
   int32 res;
   return(res);
   int32 res;
   return(res);
   int32 res;
   return(res);
   int32 res;
   return(res);
   int32 res;
   return(res);
      /* Round 1. */
    /* Round 2. */
   /* Round 3. */
   int i,j;
   for(i=0;i<16;i++)
      extmssg[i]=0;
   extmssg[0] = 1;
   a = 0x01234567;
   b = 0x89abcdef;
   c = 0xfedcba98;
   d = 0x76543210;
      for(j=0;j<=15;j++)
      aa=a;
      bb=b;
      cc=c;
      dd=d;
      round1a(a,b,c,d);
      round1b(a,b,c,d);
      round1c(a,b,c,d);
//      round1d(a,b,c,d);
//      round2a(a,b,c,d);
//      round2b(a,b,c,d);
//      round2c(a,b,c,d);
//      round2d(a,b,c,d);
//      round3a(a,b,c,d);
//      round3b(a,b,c,d);
//      round3c(a,b,c,d);
//      round3d(a,b,c,d);
//      round4a(a,b,c,d);
//      round4b(a,b,c,d);
//      round4c(a,b,c,d);
//      round4d(a,b,c,d);
      a += aa;
      b += bb;
      c += cc;
      d += dd;
Humberto
PostPosted: Wed Jul 20, 2005 3:53 pm     Reply with quote
MD5 mostly is running in 32 bit machines and it was conceived for that I guess.
Donīt know if somebody had ported to 8 bit. If you are out of ROM, I would get
the PCH and swap to 18F family without any change in the hardware.
Reading your code I guess that it is an important working project not just an evening hobby.
Best wishes,
Humberto
Regarding multiple posting
Could be possible to modify the handler in such a way that when the "button_click"
Submit is pressed once, it can disable itself to ovoid sucesive postings.?
