interrupts
nash7
interrupts
PostPosted: Tue Jul 19, 2005 11:44 am     Reply with quote
does anybody knows if you can change a general variable in a interrupts so you can use it in the main program?and how you can make that?
Thanks a lot...
PostPosted: Tue Jul 19, 2005 12:55 pm     Reply with quote
Declare a global variable. Set it in the isr, and read it in your main
program. See the sample program in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=17041
treitmey
PostPosted: Tue Jul 19, 2005 1:08 pm     Reply with quote
If the variable is declared outside/before main() then the scope will be global and it can be used in a ISR.
#include <18f452.h>
#case
#use delay(clock=16000000)
#fuses hs,nowdt,noprotect,nolvp
#use rs232(baud=19200,xmit=PIN_B4,invert,stream=DEBUG)
#zero_ram
BOOLEAN idle_bus;
//---------------- MAIN --------------------
  idle_bus=FALSE;
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
  set_timer1(INT_TIMER1);
  fprintf(DEBUG,"Starting\n\r");
    fprintf(DEBUG,".");
    if(idle_bus)
      fprintf(DEBUG,"Bus is idle\n\r");
      idle_bus=FALSE;
//=======================timer 1 ISR============================//
#INT_TIMER1       // This is called when timer 1 overflows
void timer1_isr()
  idle_bus=TRUE;
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Jul 19, 2005 1:29 pm     Reply with quote
Keep in mind that when you do use a global variable, especially a 16-bit variable, that it takes more than one assembly instruction to access it. In other words, access to that variable is not "atomic".
So when I do access 16-bit variables outside an isr, I disable interrupts briefly.
e.g.
disable_interrupts(GLOBAL);
if (GLOBAL_my_16bit_var < 2000)
The reason why I disable interrupts is because the interrupt can hit anywhere in the assembly code while in the 'middle' of the if() statement above, causing unexpected results.
nash7
PostPosted: Wed Jul 20, 2005 3:55 am     Reply with quote
thanks a lot, I had a mistake and I thought that maybe it was because of the interrupt's variable, and it wasn't as you told me...
thanks again Very Happy
