function not call another function
austin
PostPosted: Fri Jul 15, 2005 10:58 am     Reply with quote
hellow all,
i make this example to monitoring the called and return of function
main() call setled and this call set_ledon but not call set_ledoff ????
the ccs c not call function with function ?????
no anderstand, please help-me
thanks
0000: MOVLW 00
0001: MOVWF PCLATH
0002: GOTO main
0003: NOP
.................... #include <16F628.h>
.................... //////// Standard Header file for the PIC16F628 device ////////////////
.................... #device PIC16F628
.................... #list
.................... #device *=16
.................... #use delay(clock=4000000)
0004: MOVLW ??65535
0005: MOVWF FSR
0006: BCF STATUS.7
0007: MOVF INDF,W
0008: BTFSC STATUS.2
0009: GOTO 019
000A: MOVLW 01
000B: MOVWF @78
000C: CLRF @77
000D: DECFSZ @77,F
000E: GOTO 00D
000F: DECFSZ @78,F
0010: GOTO 00C
0011: MOVLW 4A
0012: MOVWF @77
0013: DECFSZ @77,F
0014: GOTO 013
0015: NOP
0016: NOP
0017: DECFSZ INDF,F
0018: GOTO 00A
0019: GOTO 023 (RETURN)
.................... #fuses NOWDT, INTRC_IO, PUT, NOPROTECT, NOBROWNOUT, MCLR, NOLVP, NOCPD
.................... void set_ledon(){
.................... output_high( PIN_B0 );
001A: BSF STATUS.5
001B: BCF TRISB.0
001C: BCF STATUS.5
001D: BSF PORTB.0
.................... void set_ledoff(){
.................... output_low( PIN_B0 );
0025: BSF STATUS.5
0026: BCF TRISB.0
0027: BCF STATUS.5
0028: BCF PORTB.0
.................... void setled(){
.................... set_ledon();
.................... delay_ms(500);
001E: MOVLW 02
001F: MOVWF @@22
0020: MOVLW FA
0021: MOVWF ??65535
0022: GOTO @delay_ms1
0023: DECFSZ @@22,F
0024: GOTO 020
.................... set_ledoff();
0029: GOTO 032 (RETURN)
.................... void main(){
.................... int x;
002A: CLRF FSR
002B: BCF STATUS.7
002C: MOVLW 1F
002D: ANDWF STATUS,F
002E: MOVLW 07
002F: MOVWF ADCON0
.................... x = 0;
0030: CLRF x
.................... do{
.................... setled();
0031: GOTO setled
.................... x += 1;
0032: MOVLW 01
0033: ADDWF x,F
.................... }while( x <= 10 );
0034: MOVF x,W
0035: SUBLW 0A
0036: BTFSC STATUS.0
0037: GOTO 031
0038: SLEEP
PostPosted: Fri Jul 15, 2005 11:07 am     Reply with quote
A classic error.
void setled(){
  set_ledon();
  set_ledoff();
The function set_ledoff is called, but within a few microseconds you are calling set_ledon again. The led is going off but only so short that you don't see it.
Change to:
void setled(){
  set_ledon();
  set_ledoff();
Mark
PostPosted: Fri Jul 15, 2005 2:14 pm     Reply with quote
If a function is only called once then it is inline unless you specify it with #separate. Notice that
0025: BSF STATUS.5
comes right after
001E: MOVLW 02
001F: MOVWF @@22
0020: MOVLW FA
0021: MOVWF ??65535
0023: DECFSZ @@22,F
0024: GOTO 020
24 then 25
The reason that it might seem like the function is not being called is what ckielstra pointed out.
austin
PostPosted: Fri Jul 22, 2005 12:29 pm     Reply with quote
ok, thanks
