rs232 with 7bit 2stop bit
reini
PostPosted: Fri Jul 15, 2005 10:15 am     Reply with quote
help! how can you use the integratet UART with 7bit and 2stop bit?
PIC18F4550. I did not find any information to any PIC with UART.
Humberto
PostPosted: Fri Jul 15, 2005 10:36 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=20501&highlight=rs232+stop
Best wishes,
Humberto
PostPosted: Fri Jul 15, 2005 11:01 am     Reply with quote
There is no direct support for 7N2, both in hardware or software UART. It is easy to simulate when you realise that a stop bit equals a databit with a logic high level. Data is transmitted with the least significant bit first. The trick is to configure RS-232 for 8N1 and make sure to set the most significant bit (MSB) for every byte sent.
#use rs232(baud=9600, xmit=PIN_TX, rcv=PIN_RX, parity=N, bits=8)
// Function to send data as 7 bits, 2 stop bits.
void Put7N2(int8 Databyte)
  bit_set(DataByte, 7);  // Simulate an extra stop bit by setting the MSB
  putc(DataByte);
  printf(Put7N2, "Hello world.\n\r");
  while(1)  ;   // Loop forever, prevent the processor going to sleep
Note: I haven't tested this code, but you get the idea.
