Mike M. Guest
| Which port caused interrupt |
Posted: Mon Dec 03, 2001 5:28 pm |
If I have 2 serial ports (one HW, one SW) and I am using the RDA interrupt, how can I tell which port caused the interrupt?
I searched the archives but all I got were people asking how to use more than one port. I can do that, I just want to be able to tell which port to read from when the interrupt comes in.
Thanks,
Mike
___________________________
Original Post ID: 1437 |
| Re: Which port caused interrupt |
Posted: Mon Dec 03, 2001 6:45 pm |
:=If I have 2 serial ports (one HW, one SW) and I am using the RDA interrupt, how can I tell which port caused the interrupt?
:=I searched the archives but all I got were people asking how to use more than one port. I can do that, I just want to be able to tell which port to read from when the interrupt comes in.
INT_RDA is only used by the hardware USART. It's not
used by the software USART.
You can use INT_EXT with the software USART, to get a
receive interrupt. Set the edge to H_TO_L, then use
getc() to get the character when you're inside the INT_EXT isr.
Original Post ID: 1440 |
