PIC16F628A and LCD driver
glavic
PostPosted: Wed Jul 13, 2005 10:56 am     Reply with quote
I am writing my own LCD driver, because driver included in CCS inst alowing you to define each pin.
main.c
#include <16F628A.h>
#fuses NOWDT, PUT, NOPROTECT, BROWNOUT, NOMCLR, NOLVP, INTRC_IO, NOCPD
#include <driver.lcd.c>
void main ()
   delay_ms(200);
   while (true)
driver.lcd.c
#define   LCD_rs   PIN_B1
#define   LCD_en   PIN_B0
#define   LCD_d4   PIN_B4
#define   LCD_d5   PIN_B5
#define   LCD_d6   PIN_B6
#define   LCD_d7   PIN_B7
BYTE const LCD_INIT_STRING[5] =
   0x28,   // function set         [2 lines, 5x10 dots]
   0x10,   // cursor or display shift   [cursor move=off, shift to the left]
   0x0C,   // display on/off control   [display=on, cursor displayed=off, cursor blinks=off]
   0x06,   // entry mode set         [decrement, don't shift display]
   0x01      // clear display
void lcd_clock ()
   delay_us(2);
   output_high(LCD_en);
   delay_us(2);
   output_low(LCD_en);
void lcd_send_nibble (byte n)
   output_bit(LCD_d4, shift_right(&n,1,0) );
   output_bit(LCD_d5, shift_right(&n,1,0) );
   output_bit(LCD_d6, shift_right(&n,1,0) );
   output_bit(LCD_d7, shift_right(&n,1,0) );
   lcd_clock();
void lcd_send_cmd (byte n)
   output_low(LCD_rs);
   lcd_send_nibble(n >> 4);
   delay_us(1);
   lcd_send_nibble(n & 0x0F);
void lcd_init()
   int count;
   output_low(LCD_rs);
   output_low(LCD_en);
   delay_ms(15);
   for (count=0; count < 3; ++count)
      lcd_send_nibble(0x03);
      delay_ms(5);
   lcd_send_nibble(0x02);
   for (count=0; count < 5; ++count)
      lcd_send_cmd(LCD_INIT_STRING[count]);
Lcd doesnt want to intialize.
R/W pin is connected to the ground, because i wont read nothing from lcd, just write.
p.s. sory for my bad English.
PostPosted: Wed Jul 13, 2005 11:39 am     Reply with quote
If you want to do it that way, then study Jon Ficks driver for ideas.
He's using a similar method:
http://www.vermontficks.org/lcdc2.htm
glavic
PostPosted: Wed Jul 13, 2005 4:43 pm     Reply with quote
Tnx, it works.
Kit
PostPosted: Thu Jul 14, 2005 3:34 am     Reply with quote
When I tried to compile the source code vermontficks.com
the compiler said that "cSkip" is undefined.
I have read through again the source code, and i have no idea what is that.
btw, i commented the if (!cSkip) and it works.
Can anyone answer my questions?
glavic
PostPosted: Thu Jul 14, 2005 4:08 am     Reply with quote
Jep, cSkip is undefined.
Just change function >
#separate void LCD_PutChar ( unsigned int cX )
    /* this subroutine works specifically for 4-bit Port A */
    if ( !cSkip )
        output_high ( LCD_RS );
        LCD_SetData ( swap ( cX ) );     /* send high nibble */
        LCD_PulseEnable();
        LCD_SetData ( swap ( cX ) );     /* send low nibble */
        LCD_PulseEnable();
        output_low ( LCD_RS );
to
        LCD_PutCmd( cX );
guest
PostPosted: Sun Jul 24, 2005 1:36 pm     Reply with quote
Same here,
No way that i am able to get the picc lcd driver running.
It works perfectly with the pic16f877, but not with the 84a or the 628a.
Why i dunno.
This one works without any problem.
regards,
Evert
guest
PostPosted: Sun Jul 24, 2005 2:04 pm     Reply with quote
Same here,
Why i dunno.
regards,
Evert
