passing dat[4] to a subroutine
jahan
PostPosted: Tue Jul 12, 2005 9:37 am     Reply with quote
I have the following subroutine:
int Validate(int a, int b, int c, int d) {
  if (a == b) && (c == d)
     return 1;
     return 0;
void main(void) {
  char dat[4];
  dat[0] = '1';
  dat[1] = '1';
  dat[2] = '2';
  dat[3] = '3';
  if (Validate(dat[0], dat[1], dat[2], dat[3]))
    output_high (PIN_A0);
How do I pass the pointer to the dat[4] to the function and use it inside the function rather than sending one char at a time as parameter to the function?
Is there a better way of doing this?
Thankx
valemike
PostPosted: Tue Jul 12, 2005 10:15 am     Reply with quote
Look how i pass in the pointer to the array. You simply call the array by name: Validate(dat)
And you can index into an array with a pointer to a char -- pChar.
pChar[2] is the same thing as writing *(pChar + 2)
#include <18F448.h>
#device ADC=8
#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT
#use delay(clock=8000000)
#ignore_warnings 202
#case
int Validate(char *pChar);
int Validate(int *pChar)
  int x;
  for (x=0; x<4; x++)
      printf ("%d: %c\r\n", x, pChar[x]);
  return 0;
  char dat[4];
  dat[0] = '1';
  dat[1] = '1';
  dat[2] = '2';
  dat[3] = '3';
  Validate(dat);
  while (1);
The output of this program is:
0: 1
1: 2
2: 2
3: 3
PostPosted: Tue Jul 12, 2005 10:19 am     Reply with quote
Try
int Validate(const char* dat) {
  if (dat[0] == dat[1]) && (dat[2] == dat[3])
     return 1;
     return 0;
void main(void) {
  char dat[4];
  dat[0] = '1';
  dat[1] = '1';
  dat[2] = '2';
  dat[3] = '3';
  if (Validate(dat))
I recommend to check the resulting size of this function as compared to your original version. The CCS compiler is very efficient when it knows the exact address of every variable. As soon as you start using pointers it is impossible for the compiler to calculate the addresses of the variables and it will generate more universal but larger code. You might be surprised to find out that your original version is larger in the editor than the second version, but smaller in the compiled version.
Edit: It's no fun to find out some other person answered the question while I was typing this message. Crying or Very sad
Sorry, I said it wrong. What I meant to say is that I pass in the ADDRESS of the array, or in other words, the address of the first element of the array.
Since pChar is a pointer to a char, then pChar now points to the first element in the array upon calling the Validate function.
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Jul 12, 2005 10:37 am     Reply with quote
I showed a demo program, and you showed exactly how the program was to be corrected. I'm sure both will help.
I can picture us all right now, when we're bored, we sit and keep refreshing the CCS forum on the browser wondering if a new post has popped up the last 3 minutes. (me, ckielstra, Ttelmah, and especially PCMPro & Mark) Laughing
jahan
PostPosted: Tue Jul 12, 2005 11:55 am     Reply with quote
Is there any difference between:
char* dat
and
char *dat
and having the world "CONST" for the parameter.
Mark
PostPosted: Tue Jul 12, 2005 12:41 pm     Reply with quote
char* dat
and
char *dat
no
not allowed
MikeValencia
valemike
PostPosted: Tue Jul 12, 2005 12:46 pm     Reply with quote
const char* dat
Isn't the above allowed as far as ANSII C goes? I think it declares dat to be a pointer to a char that is read-only, and thus the pointee's contents can't be changed.
Whether or not the CCS compiler would interpret it this way is a different story.
jahan
PostPosted: Tue Jul 12, 2005 1:18 pm     Reply with quote
     return 1;
     return 0;
void main(void) {
  char dat[4];
  dat[0] = '1';
  dat[1] = '1';
  dat[2] = '2';
  dat[3] = '3';
  if (Validate(dat))
is above example mistyped with word CONST in parameter part?
MikeValencia
valemike
PostPosted: Tue Jul 12, 2005 1:47 pm     Reply with quote
With the const, it compiles in Unix. However, it does not compile in CCS.
So delete the const, and you'll be okay.
PostPosted: Tue Jul 12, 2005 3:19 pm     Reply with quote
Sorry about the const keyword, it is indeed not valid for the CCS compiler to use it the way I did. I've been working too much in Delphi lately. C++ allows this construct as well. Embarassed
The const keyword is valid in CCS, but only to declare a constant like for example:
int8 const A = 3;
char const *B = 4;
int8 const C[3] = {1,2,3};
And yes, I checked these in v3.225. Smile
In C++ there are even more options:
const int* pX;        // A changeable pointer to a constant int.
int* const pY;        // constant pointer to changeable int
const int* const pZ;  // const pointer to const int
See also http://www.possibility.com/Cpp/const.html for a more in depth description.
Good thing about these constructions is that it allows the compiler to do some extra type checking and create better optimized code.
