i use the interrupt on change on portb. I detect the signals on portb4-portb7.
in the interrupt-routine #int_rb i detect the changes on portb.
BUT:
the interrupt_flag RBIF will be cleared at the end of the routine.
What is if i get signal during the interupt - routine, but the RBIF is set and only cleraed at the end!
Do you think I will get a loss of data??
Best wishes,
Mike
Mark
Posted: Tue Jul 12, 2005 6:31 am
That's why you keep the interrupt as short as possible. You can also use the NOCLEAR option and clear the flag yourself at the begining of the routine.
Posted: Tue Jul 12, 2005 6:35 am
Remember also, that you must read the port, before resetting the flag.
