memory
younus_noman
memory
PostPosted: Sat Jul 09, 2005 11:00 pm     Reply with quote
I was using pic16f876 with ccs compiler but i found out that it just has 368 bytes of memory availabe but i need 2kilo bytes of memory.
Can i use 18f series with my ccs compiler and i dont have the header files.
How do i find out if the 18f series with larger memory space supports my compiler.
any ideas
thanks
Noman Younus
Mark
PostPosted: Sat Jul 09, 2005 11:11 pm     Reply with quote
If your compiler is PCH then it will. If you don't have the header files then you probably don't have PCH. PCM is the compiler for the 16's.
