Help: Can't Get Function to Work for PWM
Dale Stewart
PostPosted: Fri Jul 08, 2005 10:08 pm     Reply with quote
Hi
I am a newbie to PICs and learning CCS C.
My project is a small robot, and I want to write a simple function to control the speed and direction of DC motors using PWM.
The code I wrote before worked fine. However when I tried to encapsulate this code as a function to control the motors - it won't work.
I already tried using integer variables as arguments instead of constants when calling the function.
Question The problem doesn't seem to be a simple logic error, but something to do with CCS C coding ???
Any thoughts are most welcome.
Here is the code - please just focus on the function prototype, call, and definition and ignore the superfluous code, as it already works otherwise and has been tested thoroughly.
// Motors_Main.c
// Date: 09 July 05
// Author: Dale T Stewart
// Purpose:
//  The main code template for motors
// Test Notes:
//  1. Robot motors running at ~4.8V supply via Texas
//   Instruments SN754410NE motor driver.
// Hardware notes:
//  1. Oscillator value affects frequency of PWM output
//     to motors.
//  2. Motor direction control bits. Motors orientation and wiring
//     need to be taken into consideration. See associated notes on
//     Project #1.
#include <16F876A.h>
#fuses HS, NOWDT, NOPROTECT, NOLVP
#use delay( clock = 8000000 )   // 8MHz oscillator
//   Motors Section
#define PERIOD 255      // 255 is maximum period?
#define POSTSCALE 1   // 1 ( fastest ) to 3 ( slowest )
//  Select and define custom register names
#byte motors_Port_C = 7    // Select Port C address register
// Constants for motors speed
// Motor1 = RHS      Motor2 = LHS
//            SPEED   Dec     ~DUTY CYCLE ( % )   Relative Speed
#define SPEED_1   77      //  30           Minimum
#define SPEED_2 102      //  40              |
#define SPEED_3 128      //  50              |
#define SPEED_4 153      //  60              |
#define SPEED_5 179      //  70              |
#define SPEED_6 204      //  80              |
#define SPEED_7 230      //  90              v
#define SPEED_8 255      // 100           Maximum
//   DIRECTION - CONTROL BITS FOR MOTOR DIRECTION
//   These depend on motors orientation and wiring.
//   See associated notes on Project #1
#define FORWARD        0b01010110
#define REVERSE          0b10100110
#define TURN_LEFT       0b10010110
#define TURN_RIGHT     0b01100110
#define COAST          0b00000000
#define BRAKE_1          0b11110110
#define BRAKE_0          0b00000110
#define LEFT_FORWARD   0b01000010
#define LEFT_REVERSE    0b10000010
#define RIGHT_REVERSE  0b00100100
#define RIGHT_FORWARD  0b00010100
//      Motors prototype
void motors( int dir, int spd );
//        START MAIN
  //         Motors Setup
  // Motors: Setup data direction registers
  set_tris_c( 0x00 ) ;    // Set Port C data direction register to            // output
  //    Motors: Setup CCPx pins for PWM mode
  setup_ccp1( CCP_PWM ) ;   // Configure CCP1/RC2 as a PWM
  setup_ccp2( CCP_PWM ) ;   // Configure CCP2/RC1 as a PWM
  //    Motors: Setup Timer2 times and frequencies
  //   The cycle time will be (1/clock)*4*t2div*(period+1)
  //   In this program clock=8000000 and period = 255 (below)
  //   For the three possible selections the cycle time is:
  //     (1/8000000)*4 * 1  * 256  =   128    us  or  781.3 kHz
  //     (1/8000000)*4 * 4  * 256  =   512    us  or  195.3 kHz
  //     (1/8000000)*4 * 16 * 256 =      2.05 ms  or  488.3  Hz
  setup_timer_2( T2_DIV_BY_1 , PERIOD, POSTSCALE ) ;
  //      End motors setup
  while( 1 == 1 )    // Chase your tail - woof!
    //           GO FORWARD
    motors( FORWARD, SPEED_7 );
  } // end while
}  // end main
//      END MAIN
//       Function Definitions
//   Function: void motors( int direction, int speed )
//  Purpose: Control motors speed & direction
   int d, s;
   motors_Port_C = d ;
   set_pwm1_duty( s ) ;
                set_pwm2_duty( s ) ;
Cheers
Dale
PostPosted: Fri Jul 08, 2005 10:49 pm     Reply with quote
In the function below, you're not using the passed parameters of
direction and speed. Instead, you're using a couple un-initialized
local variables for Port C and the duty cycle functions. You need
to get rid of the locals, and use your function parameters.
int d, s;
motors_Port_C = d ;
Also, I would reduce the number of asterisk lines. To me, they distract
attention from the code. Before I looked at your code, I copied it to
MPLAB and deleted all those lines. Then I saw the problem right away.
Dale Stewart
PostPosted: Fri Jul 08, 2005 11:12 pm     Reply with quote
Hi PCM
Thanks heaps for your help and effort!
Cool - it works!
I am just learning C and am rusty on functions- it was a dumb mistake. Embarassed
Yeah I guess I do use a lot of asterisks to try and organise the code into sections - do you use another method?
Cheers
Dale
PostPosted: Fri Jul 08, 2005 11:50 pm     Reply with quote
If you want to see my commenting style, you can see it in my post
near the end of this link. I separate functions with dashed lines.
http://www.ccsinfo.com/forum/viewtopic.php?t=23359
Everyone has their own style and I realize that when you're starting
out, you need more comments. My only reservation is that, for me,
using lines asterisks between lines of code is distracting.
