rnielsen
Odd or even number |
Posted: Fri Jul 08, 2005 10:21 am |
This may be a dumb question but what's an easy way to determine if a number(variable) is odd or even?
Ronald |
Re: Odd or even number |
Posted: Fri Jul 08, 2005 10:25 am |
rnielsen wrote: | This may be a dumb question but what's an easy way to determine if a number(variable) is odd or even?
Ronald |
For an integer, it couldn't be easier!. Use a bitwise '&' with '1'. If this is non-zero (true), the number is odd.
So:
#define isodd(x) ((x)&0x1L)
//Use this like:
if (isodd(value)) {
//Here the number was odd
sseidman
Posted: Fri Jul 08, 2005 10:26 am |
Ronald |
Assuming an integer, if the LSB is zero, the number is even.
Scott |
You just test the LSB. |
kender
Posted: Fri Jul 08, 2005 10:51 am |
if (n & 0x01)
// odd
// even
rnielsen
Posted: Fri Jul 08, 2005 11:06 am |
Thanks. I like the LSB bit test. Simple.
Ronald |
Posted: Fri Jul 08, 2005 3:21 pm |
I have to wonder if this thread was actually a 'record'. Four answers, all with basically the same solution in one minute!. I have seen a couple of overlapped answers before, but four is pretty amazing. :-)
Given that the writers, can't see other answers 'in preparation', it shows a remarkable activity level on the group.
treitmey
Posted: Fri Jul 08, 2005 3:49 pm |
Great minds think alike. |
