understanding the pic .hex file format
Nick
PostPosted: Thu Jul 07, 2005 9:30 pm     Reply with quote
I'm adding a simple encryption to a boot loader.
":1000000010308A0000280000FF00030E8301A100C9"
is the first line of a hex file, can someone break down the line?
I figure it has the address, data, and a check sum value
also sometimes i see lines that start with :0 what are those?
":0A385000272C99008A01002800349B"
Thanks Nick
PostPosted: Thu Jul 07, 2005 11:39 pm     Reply with quote
Read the Microchip TB025 document, which talks about downloading
HEX files to PICs and explains the HEX file format.
http://ww1.microchip.com/downloads/en/AppNotes/91025a.pdf
asmallri
Re: understanding the pic .hex file format
PostPosted: Fri Jul 08, 2005 4:08 am     Reply with quote
If you are going to build simple encryption then one challenge you will have to work with is that the record format is "well known". Generally records are a fixed length - this gives an obvious clue to the record format. Certain records are constant such as type 4 records. When constant records occur it is relatively easy to break the encryption. You will effectively need to pad all records to the same length. You have to have a psuedo random pad otherwise type 4 records can be readily identified. Once these are identified then it becomes easier to determine the key to break the rest. The encryption algorithm has to be such that changing a single byte (such as would be the case of a minor code change) should result in the charge in a large number of records (ideally all records) without any obvious pattern.
Regards, Andrew
Nick
PostPosted: Fri Jul 08, 2005 5:06 am     Reply with quote
1. Only encyrpt type 0 codes
2. Only encrypt the four digit hex- words and the checksum
those are going to be my rules.
example
non-enc
enc
:10000000KFIJI4OI3KL409FKFKLEOI904983IO489390
so the format is not broken and can be programmed ;-)
Nick
