Problem with ds1302
ferrarilib
Problem with ds1302
PostPosted: Wed Jul 06, 2005 1:31 pm     Reply with quote
hallo i have problem with ds1302 give to me always 1:1:1
my code is this:
#include <16F877.h>
#use delay(clock=8000000)
#include <DS1302.C>
BYTE day=1,mth=2,year=3,dow=4,hour=5,min=6,sec=7;
//bcd def
const unsigned int conv[16] = {
0,10,20,30,40,50,60,70,80,90,90,90,90,90,90,90 };
#define fromBCD(x) ((x & 0xf)+conv[(x>>4)])
unsigned int toBCD(unsigned int val)
int ctr;
for (ctr=0;ctr<10;ctr++)
if (val == conv[ctr])
return(ctr<<4);
else if (val < conv[ctr]) break;
--ctr;
return((val-conv[ctr])+(ctr<<4));
} // end bcd def
byte get_bcd() {
char first,second;
do {
first=getc();
} while ((first<'0') || (first>'9'));
putc(first);
first-='0';
do {
second=getc();
} while ((second<'0') || (second>'9'));
putc(second);
return((first<<4)|(second-'0'));
void set_clock()
puts("Year 20: ");
year=get_bcd();
puts("Month: ");
mth=get_bcd();
puts("Day: ");
day=get_bcd();
puts("Weekday 1-7: ");
dow=get_bcd();
puts("Hour: ");
hour=get_bcd();
puts("Min: ");
min=get_bcd();
puts("sec");
sec=get_bcd();
printf("\n\r %2d,%2d,%2d, %2d um %2d:%2d\n",fromBCD(day),fromBCD(mth),fromBCD(year),fromBCD(dow),fromBCD(hour),fromBCD(min));
rtc_set_datetime(day,mth,year,dow,hour,min);
printf("\n\r clock setup");
void get_clock()
rtc_get_time(hour,min,sec);
printf("\n\r...%2d:%2d:%2d...\n",fromBCD(hour),fromBCD (min),fromBCD(sec));
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
rtc_init();
printf("\n\r...start...\n");
set_clock();
do {
get_clock();
get_clock();
} while (TRUE);
} //end main
i have tired cange chip too but always 1:1 :1
i have connect so :
#define RTC_SCLK Pin_A2
#define RTC_IO Pin_A3
#define RTC_RST Pin_A4
but nothing works
there is sameone that can help me ?
Thanks..
PostPosted: Wed Jul 06, 2005 1:41 pm     Reply with quote
Have you tried to use the CCS example file, EX_RTCLK.C with
the ds1302 driver file DS1302.C ?
The example file is in this folder: c:\Program Files\Picc\Examples
I suggest that you get it working first with the CCS example file,
and then try your own code.
ferrarilib
PostPosted: Wed Jul 06, 2005 3:43 pm     Reply with quote
i dont can try with this example because i dont have keyboard in a pic..
Confused
ferrarilib
PostPosted: Wed Jul 06, 2005 4:01 pm     Reply with quote
ok i have tired with manual set day,mth,year,dow,hour,min but output is always 01:01:01
in the date and in the time ..
I think that is a comunicate problem !
my set is :
Pic ds1302
A2------> 7
A3------> 6
A4------> 5
2---> XL 32,768
3--->none
1---->+5v
8---->+3,3 Batt
Confused
but need in A4 a resistor to Vcc ?
ferrarilib
PostPosted: Wed Jul 06, 2005 4:18 pm     Reply with quote
Now works fine but with ressistor of 1,5K vcc---> A4
But why need this resistor for works ?
PostPosted: Wed Jul 06, 2005 4:20 pm     Reply with quote
A2------> 7
A3------> 6
A4------> 5
2---> XL 32,768
3--->none
1---->+5v
8---->+3,3 Batt
The crystal should connect to pins 2 and 3. The crystal has two
wires coming from it. One wire goes to pin 2 and the other wire
goes to pin 3.
Also, you need a pull-up resistor on pin A4 of the PIC.
Pin A4 is an open-drain output pin on most PICs.
You can use a 4.7K resistor. One side should connect to
pin A4, and the other side to +5v.
ferrarilib
PostPosted: Wed Jul 06, 2005 4:41 pm     Reply with quote
PCM programmer wrote:
A2------> 7
A3------> 6
A4------> 5
2---> XL 32,768
3--->none
1---->+5v
8---->+3,3 Batt
goes to pin 3.
PCM Thanks !!
my XL is epson cristal and have only 1 pin output . one is for v+ one ground one out ..
Thanks Razz
