If I have four EEPROMS communicating to a PIC using i2c. Do I need a 2kOhm pull up resistor for each each EEPROM on the SCL and SDA lines?
Or can I use just one set of pull up resistors (2 in number)?
Thank you in advance
arrow
rnielsen
Posted: Wed Jul 06, 2005 10:34 am
You only need one resistor on each bus line (2 resistors total). The resistors are not for each eeprom but for the bus line itself. Try using between 2k - 4k first.
