16F88: output_high(pin_a5) stays low - output_a(0x20) works
mikesters
PostPosted: Wed Jul 06, 2005 5:26 am     Reply with quote
hi,
on 16F88 i need pin_a5 to work just like the others.
if i set a5 and a6 to high, only a6 goes high. if only set a5 to high it works just fine. a5 stays low (only) in combination with a6 and a7. what am i doing wrong?
thanx for helping
#include <16F88.h>
#fuses NOWDT,INTRC_IO, NOPUT, NOMCLR, NOLVP, NOBROWNOUT, NOCPD, NOWRT, NODEBUG, NOPROTECT, NOFCMEN, NOIESO
   setup_adc(ADC_OFF);
   set_tris_a(0);
      Output_high(PIN_A5);
      Output_high(PIN_A6);
      delay_cycles(100);
      Output_low(PIN_A5);
      Output_low(PIN_A6);
      delay_cycles(100);
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Jul 06, 2005 7:53 am     Reply with quote
I'm looking at the datasheet. RA5 is designated as an INPUT only. Unfortunately, you'll have to find another pin; if you're out of pins, then swap RA5 with another pin that you are using as an input.
Humberto
PostPosted: Wed Jul 06, 2005 7:56 am     Reply with quote
mikesters wrote:
Read the datasheet. In page 10 you will see that A5 is an INPUT PIN
Best wishes,
Humberto
