KALKAN
Set tris doesn't work |
Posted: Mon Jul 04, 2005 7:42 am |
I made down counter with LED display. I want to use RB0 to INT. I read set_tris_b(0b0000001). But I cant use INT. What can I do?
#include <16F628.h>
#use delay ( clock = 6000000 )
#fuses HS,NOWDT,NOPROTECT,NOLVP,nomclr
BYTE CONST LED_MAP[10] = {0x7e,0x0c,0xb6,0x9e,0xcc,0xda,0xfa,0x0e,0xfe,0xde};
char saya,sayac=9,say=9, say1=9,say2=9;
#INT_EXT
void ext_isr(void)
static short button=TRUE;
if(button ){say--;}
void display_segs(char c)
output_b(LED_MAP[c]);
void display(char bir, char iki,char uc, ) {
display_segs(bir);
output_high(PIN_a0);
delay_ms(5);
output_low(PIN_a0);
display_segs(iki);
output_high(PIN_a1);
delay_ms(5);
output_low(PIN_a1);
display_segs(uc);
output_high(PIN_a2);
delay_ms(5);
output_low(PIN_a2);
void gos(void)
if(say==-1)
say1--;
say=9;
if(say1==-1)
say2--;
say1=9;
if(say2==-1)
say2=9;
if(input(pin_a5))
say=0, say1=0,say2=0;
ext_int_edge(H_TO_L);
enable_interrupts(INT_EXT);
set_tris_B(0x01);
display(say, say1, say2);
gos();
newguy
Posted: Mon Jul 04, 2005 8:04 am |
Do you have an external pullup on B0? If not, use:
Code: | enable_pullups(TRUE); |
Posted: Mon Jul 04, 2005 8:08 am |
Code: | char saya,sayac=9,say=9, say1=9,say2=9; | From the CCS manual chapter 'Data Definitions': Quote: | All types, except float, by default are unsigned; however, maybe preceded by unsigned or signed | Change your line to
Code: | signed int8 saya,sayac=9,say=9, say1=9,say2=9; |
Also be make sure to add a switch debouncing meassure or the following line is due to fail:Your switch will trigger the interrupt multiple times, so the variable 'say' will be decremented multiple times and become smaller than -1.
Search this forum for debounce software. As another option you can create a hardware debounce from the Schmitt-trigger function of the Int-ext input and adding an external R/C combination with a time constant of minimal 10ms. |
