RodP
LCD A1,A2,A3 & data lines on d4,d5,d6,d7 |
Posted: Sat Jul 02, 2005 8:44 am |
I'm using the origional PicDem - 2 (not Plus) board for prototyping. My problem is getting my 2-line, 20 character LCD to work with it. I'm using the modified LCD.c code written by Mark with the appropriate pin changes but it doesn't work. I know the device is ok because it works from the same board and chip using a PicBasic program. Any help would be greatly appreciated! Code: | ////////////////////////////////////////////////////////////////////////////
//// LCDD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// (C) Copyright 1996,1997 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
// This structure is overlayed onto the data ports so that you may use
// whatever ports you desire
struct lcd_pin_map
BOOLEAN dummy; // PinA0 is not used
BOOLEAN enable; // PinA1
BOOLEAN rw; // PinA2
BOOLEAN rs; // PinA3
int unusedA : 4; // The rest of portA
int unusedB; // portB is not used
int unusedC; // portC is not used
int unusedD : 4;// \ Changed so lower nibble of portd is unused
int data ; // / and upper nibble is data
} lcd;
#if defined(__PCH__)
#locate lcd = 0xF80
#else
#locate lcd = 5
struct lcd_tris_map
int control : 3;
int unusedB: 8; // portB is not used
int unusedC: 8; // portC is not used
int unusedD: 4; // \
int data : 4;// / Change to use the upper nibble of portd for data instead of the lower
} lcdtris;
#locate lcdtris = 0xF92
#else
#locate lcdtris = 0x85
#define set_tris_lcd(x) lcdtris.data = (x); lcdtris.control = 0;
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
//BYTE const LCD_INIT_STRING[4] = {0x28, 0xd,1,6};
//BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0x0d, 1, 6};
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xf, 1, 6};// Cursor underlined and blinking
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
#define LCD_WRITE 0 // For write mode all pins are out
#define LCD_READ 15 // For read mode data pins are in
BYTE lcd_read_byte() {
BYTE low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);// send 3 - threes
delay_ms(5);
lcd_send_nibble(2);// 4 bit mode
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
treitmey
Posted: Tue Jul 05, 2005 7:39 am |
Port A may mean open collector, thus you will need pull-up on them.
Try this and see if it helps. |
