sensor ...
Bibi
sensor ...
PostPosted: Fri Jul 01, 2005 3:00 am     Reply with quote
i have a sensor that is 1 when (!input(sensor)) and 0 when (input(sensor)).
What i want to do is to count if it is pressed 6 times in an interrupt.
It should be something pretty much like this :
counter = 0;
button_pressed_6_times = 0;
if (!input(sensor)){        // Wait for Enter Button to be pressed
while (!input(sensor));   // Wait for Enter Button to be released
counter +=1;                // counts how many times it is pressed
if(counter == 5) button_pressed_6_times == 1;
Will that work or does someone has an idea ?
The thing that is difficult is that it should be in an interrupt ...
Thank you very much.
valemike
Re: sensor ...
PostPosted: Fri Jul 01, 2005 5:13 am     Reply with quote
Bibi wrote:
[/code]
Wait. You want to stay this long in an interrrupt service routine? Don't do that. Your interrupt should get in and out within microseconds. Defer this counting six times for your main loop.
counter = 0;
This should be:
if (counter == 5)
button_pressed_6_times = 1;
There is something clumsy about staying long in an interrupt service routine. But if you do insist on staying in the ISR, the above code, with the "==" correction should work. Make sure those variables are Global though; i don't see how or where they are initialized.
Bibi
PostPosted: Fri Jul 01, 2005 5:25 am     Reply with quote
If it is not in an isr how could i do ?
The variables are global exact !
Bibi
PostPosted: Fri Jul 01, 2005 6:30 am     Reply with quote
I forgot to say that it should be pressed 6 times for a period of 30 seconds.
So if the button is pressed 6 times during 30 seconds button_pressed_6_times == 1;
sseidman
PostPosted: Fri Jul 01, 2005 7:11 am     Reply with quote
That's a MUCH different problem, and you need to define it a little better. Do you mean 30 seconds from the first button press, or any 6 presses within 30 seconds? With the first, you would start a 30 second timer on the first button press, and reset things if the timer reaches 30 seconds and six presses have not occured. The second cas is much more complex.
Be careful about button bounce, as well.
Scott
Bibi
PostPosted: Fri Jul 01, 2005 7:18 am     Reply with quote
It should be 6 presses in 30 seconds, the first press starts the process and then ther are 30 secondes left for the button to be pressed 5 more times to the process to be ok if not nothing happens.
asmallri
PostPosted: Fri Jul 01, 2005 8:48 am     Reply with quote
Don't forget to do some debouncing of the switch
Regards, Andrew
Bibi
PostPosted: Mon Jul 04, 2005 1:50 am     Reply with quote
Do have any other idea ?
Bibi
PostPosted: Mon Jul 04, 2005 6:09 am     Reply with quote
PLEASE HELP !!!! Crying or Very sad
valemike
PostPosted: Mon Jul 04, 2005 7:10 am     Reply with quote
Do you want code?
ex_stwt1.c
or
ex_stwt.c
or
ex_stwt2.c
in the CCS examples directory that comes with every version of the compiler
Read it and you'll find you can set up your isr. Then look the main. It counts the timing between two events (you press a key two consecutive times and it tells you how many seconds elapsed between the two keypresses).
With a few changes, you can have this example work for you.
