counting hours
Christophe
counting hours
PostPosted: Thu Jun 30, 2005 6:39 am     Reply with quote
every time I switch the device off, I want the timer1 to start counting hours, after 24 hours, the PIC should do something and go to sleep.
Unfortunately, my PIC counts wrong:
//************************** Timer1 interrupt ********************************//
//Timer1 wordt gestart als de NS uit staat
#int_timer1
Timer1_isr()
      if(int_count++ == 2)
            ++secs;
            if(secs==10)
                putc('E');
               //mins=mins+1;
                secs=0;
                setup_timer_1(T1_DISABLED);
           // if(mins==60)
             //  hrs=hrs+1;
              // mins=0;
         /*   if(hrs == 2)
               hrs=0;
         int_count = 0;
      Set_Timer1 ( 0x0BDB);
}// TIMER1
//************************** EXTERNAL interrupt ******************************//
//Interrupt als de AAN/UIT schakelaar wordt bewogen
#INT_EXT
void ext_isr()
   int8 i;
   for (i = 0; i < 30; i++)         // Debounce
      delay_us(999);
   if (input(AAN_UIT))
      E3_SLEEP = FALSE;
      sleep_mode = FALSE;
       E3_SLEEP = TRUE;
       setup_timer_1( T1_INTERNAL| T1_DIV_BY_8 );
       Set_timer1 ( 0x0BDB); // Start de Timer1 vanaf
   if (E3_SLEEP)
      printf("%c%S%c",COMMANDO_BYTE, SLEEP_COMMANDO,0);
      ext_int_edge(L_TO_H);
      setup_uart(TRUE);
      if (!sleep_mode)
         printf("%c%S%c",COMMANDO_BYTE, WAKE_COMMANDO,0);
      ext_int_edge(H_TO_L);
Neutone
PostPosted: Thu Jun 30, 2005 7:28 am     Reply with quote
Think about how this works. You could do the same with timer 1.
*    Initialize RTC                          *
void Initialize_RTC(void)
{  Ticker = XTAL_FREQUENCY;
   setup_timer_2 ( T2_DIV_BY_4, 0xff, 4 );   // initialize 8 bit counter/timer 2 to interupt every 16384 clock cycles
   enable_interrupts( INT_TIMER2 );          // Start RTC
// Global Real Time Clock Information
#int_TIMER2                                  // Clock interrupt adjusted to occurs ~ 1ms
void TIMER2_isr()                            //  -=Process Zero Drift Real Time Clock Information=-
{  tickmSec = 1;                             // set each MS very approximately
   Ticker -= 16384;                          // Decrement ticker by clocks per interupt
   if ( Ticker < 16384 )                     // If second has expired
   {  Ticker += XTAL_FREQUENCY;              // Increment ticker by clocks per second
      second++;                              // Increment number of seconds
      tickSec = 1;                           // set each Second very accuratly
Christophe
PostPosted: Thu Jun 30, 2005 7:35 am     Reply with quote
well,
I could it with timer2; difference:
Timer2: interrupt every 16384 us (your example)
Timer1: interrupt every 50000 us (1/2 s)
What you think is most efficient?
In the meanwhile I found the bug.. thanks f|#C=n CCS:
the bug is this statement:
Timer1_isr()
      {      blabla;... }
should be:
Timer1_isr()
      int_count++;
      if(int_count == 2)
      {      blabla;... }
Don't ask me why, but it works now.. took me some hours :\
PostPosted: Thu Jun 30, 2005 7:55 am     Reply with quote
The two statements are different.
In the 'new' one, you increment the value _before_ testing it.
The equivalent 'combined' statement, is:
Timer1_isr()
      if(++int_count == 2)
      {      blabla;... }
Note where the '++' is. Putting it in front of the variable, means 'increment, then take the value'.
However the syntax 'int_count++', means take the value, _then_ increment the variable.
This will give an extra 'count' in the interrupt routine, before the value is seen to be right.
Christophe
PostPosted: Thu Jun 30, 2005 8:39 am     Reply with quote
Just tested that,
it's true, thanks again for the information
