ferrarilib
ccp Questions |
Posted: Thu Jun 30, 2005 2:16 am |
i am doing rpm counter and i am using cpp metode
#INT_CCP1
ccp1_isr()
Value=CCP_1-oldValue;
oldValue=CCP_1;
gotCCP1 = TRUE;
float freq;
char i;
Value=0;
oldValue=0;
gotCCP1 = TRUE;
setup_ccp1(CCP_CAPTURE_RE); // CCP1 - rising edge
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);// Timer1 interrupt
enable_interrupts(INT_CCP1);
set_tris_C(0xAF); // All inputs except C4 and C6
while(TRUE) { // Start main program loop (endless)
while(!gotCCP1) // when is false stop and return 0.
Value=0;
freq=1.0/((float)Value*2e-6);
printf("Freq%f\r\n",freq);
gotCCP1 = FALSE;
}// while
but when i dont input signal the the output insn' t 0 but sametime the frequency sametime 0 !
there is sameone that can help me ?
how i can know when cpp interput is not used ?
thanks |
Haplo
Posted: Thu Jun 30, 2005 3:25 am |
How is the variable 'value' defined? If the timer overflows between two rising edges (which it will), the line 'Value=CCP_1-oldValue;' may result in an incorrect value. |
asmallri
Joined: 12 Aug 2004 Posts: 1635 Location: Perth, Australia
Posted: Thu Jun 30, 2005 4:08 am |
You have forgotten to clear the CCP1 interrupt before you enabled it. The interrup flag may already be set which means you will have an interrupt event occur immediately the interrupt is enabled. In this case the first reading is rubbish..
Also you are fighting your own interrupt handler with value being set in the mainline and in the interrupt handler. This is why you are getting silly values. I suspect what you meant to do was:
disable_interrupt(INT_CCP1);
gotCCP1 = FALSE;
enable_interrupt(INT_CCP1);
}// while
_________________ Regards, Andrew
ferrarilib
Posted: Thu Jun 30, 2005 4:12 am |
int16 Value,oldValue ;
but i don't undestand .
can you do example how works ?
thanks |
ferrarilib
Posted: Thu Jun 30, 2005 4:26 am |
the problem is that when i dont have more interrupt the count stop
i have thy this too
disable_interrupts(INT_CCP1);
gotCCP1 = FALSE;
but when the frequency is 0 reurrn always the last valure
Posted: Thu Jun 30, 2005 4:35 am |
I'd say the key problem is here:
Value=0;
The problem is that lines of code take _time_.
Now imagine that you are sitting in this loop. The entire loop probably takes about 6 instructions. Immediately after the instruction testing for gotCCP being false, gotCCP goes true. The code will still execute the section corresponding to 'false' (it was false when tested...), and will _clear_ the value. Then on the next test, gotCCP is seen as 'true', and the code passes to the 'print', with a zero value...
Change the logic.
Use something like:
if (gotCCP) {
gotCCP1 = FALSE;
If you want to print something when gotCCP is not true, then simply add an 'else', and print a message. Don't clear value.
ferrarilib
Posted: Thu Jun 30, 2005 5:23 am |
Ttelmah wrote: | I'd say the key problem is here:
Value=0;
Change the logic.
Use something like:
if (gotCCP) {
gotCCP1 = FALSE;
thanks !
But i have tired this too:
//val=get_timer1()-old;
//old=get_timer1();
if(gotCCP1)
gotCCP1 = FALSE;
printf("Freq%f\r\n",mio);
}// while
where mio =0;
and return
Freq34.435260\0D
Freq.000000\0D (why is 0 ?)
Freq34.435260\0D
when capture and when not capture is good !
Freq.000000\0D
Freq.000000\0D
Freq.000000\0D
asmallri
Posted: Thu Jun 30, 2005 5:39 am |
Do this and tell us the results
if(gotCCP1)
disable_interrupt(INT_CCP1) // MUST DO THIS
enable_interrupt(INT_CCP1) // MUST DO THIS
printf("Here at A - Freq%f\r\n",freq);
gotCCP1 = FALSE;
printf("Here at B Freq%f\r\n",mio);
Posted: Thu Jun 30, 2005 6:00 am |
I think I'd clear gotCCP, before re-anabling the interrupt. This woul allow it to again 'log' an edge that occured during the print time.
ferrarilib
Posted: Thu Jun 30, 2005 6:08 am |
asmallri wrote: | Do this and tell us the results
if(gotCCP1)
gotCCP1 = FALSE;
capture :
ere at B Freq .000000 ( ? )\0D
\0A
Here at B Freq .000000 ( ?)\0D
\0A
Here at A - Freq34.435260\0D
\0A
Here at B Freq .000000\0D (?)
i think that afther do last instruction go to while (TRUE) and restart another without take valure from interrupts !
i must insert a delay time because the frequency captured is low !
and the interrupt dont have time for set variable .
so works fine :
delay_ms (100); this permit wait interrupt
if(gotCCP1)
//disable_interrupts(INT_CCP1); // MUST DO THIS don 't cange nothing in output
// enable_interrupts(INT_CCP1); // MUST DO THIS
gotCCP1 = FALSE;
}// while
now i must set 2e-6
i have 8000000 clock and do 2000000 of cicle so i think that is correct do
freq=1.0/((float)Value*2e-6); ? is good ?
thanks |
asmallri
Posted: Thu Jun 30, 2005 6:46 am |
Ttelmah wrote: | I think I'd clear gotCCP, before re-anabling the interrupt. This woul allow it to again 'log' an edge that occured during the print time.
Definately - my brain was out of gear :-) _________________ Regards, Andrew
asmallri
Posted: Thu Jun 30, 2005 6:59 am |
If you are going to use interrupts then you MUST leave the enable and disable statements in place. Interrupts WILL corrupt the results, maybe not now, maybe not tomorrow, but it is as sure as night follows day.
// the following line is not required unless for some reason you want multiple interrupts to occur
// delay_ms (100); this permit wait interrupt
if(gotCCP1)
gotCCP1 = FALSE;
// I don't know why the following line is here as no interrupt
// will have occurred to change anything from last reading
// printf("Here at B Freq%f\r\n",mio);
}// while
Quote: |
now i must set 2e-6
thanks |
I don't understand the question. _________________ Regards, Andrew
ferrarilib
Posted: Thu Jun 30, 2005 7:16 am |
asmallri wrote: | If you are going to use interrupts then you MUST leave the enable and disable statements in place. Interrupts WILL corrupt the results, maybe not now, maybe not tomorrow, but it is as sure as night follows day.
if(gotCCP1)
gotCCP1 = FALSE;
}// while
Quote: |
now i must set 2e-6
thanks |
I don't understand the question. |
you tell to me that if i am mesure the frequency with period is not stable ?
my question is now i have clock pic to 8Mhz
and i must know frequency in hz
f=1/T ---> T= period
2e-6 is the factor for have frequency in hz |
Posted: Thu Jun 30, 2005 3:17 pm |
What is the likely range of input frequencies involved?.
Remember that Timer1, is only a 16bit counter, so the maximum interval between clock edges that can be handled by the approach you are using here, corresponds to just over 30Hz (at 8MHz). If your frequency drops below this, you really need to add a timer1 interrupt, and increment a 'carry' bit, and use 32bit values for the count.
Conversely, if the frequency is relatively high, there will be significant 'jitter' in the measurement. If (for example), the time is about 0.1mSec/cycle, unless the clock is synchronous to the internal processor clock, values will jump between perhaps 199,and 201 counts, and the frequency measure will show about 1% fluctuation, even if the clock is perfectly stable.
Something seems to be 'screwy' about your maths.
As shown, a frequency of 10000Hz, will give counts around 200, and should be converted, by using:
freq=2E6/Value;
For the same count value, your conversion would give:
1/(200*2E-6) = 2500...
The single division will also need less maths time.
ferrarilib
Posted: Fri Jul 01, 2005 12:36 pm |
thanks now i undastand and my project start go on ..
yes i have implement with timer1 (#INT_TIMER1) so i have carry bite. and i have used union variable for do it to 32 bit.
I have resolve the problem whitout delay but with
if(period>2000000)
period=0;
in the CCP1 function (interrupts) so dont give to me error
and all is good now. So when the cicle is down 2000000 (1hz) the counter give to me 0. |
