Help me about CCP interupt
damsel
PostPosted: Fri Jun 25, 2004 6:29 am     Reply with quote
Hello everyone..
I can't run my code.
I used a ADXL202 to measure 2 pulse width with Capture modual.
And I want to view the output from Hyper Terminal.
But I can't see anything from my HT.
Please help me..
Thanks alot
#include <16f877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
long rise,rise2;
float A1,A2;
#int_ccp1
void isr1()  {
      rise  = CCP_1;// CCP_1 is the time the pulse went high
      A1 = ((CCP_1-7750)/7750)/0.125; //(Accleration=(T1-T2)/T2)/12.5%
#int_ccp2
void isr2()  {
      rise2 = CCP_2;// CCP_2 is the next time the pulse went high
      A2 = ((CCP_2-7750)/7750)/0.125; //(Accleration=(T1-T2)/T2)/12.5
main() {
   printf("\r\nHigh time (sampled every second):\r\n");
   setup_ccp1(CCP_CAPTURE_RE);
   setup_ccp2(CCP_CAPTURE_RE);
   setup_timer_1(T1_INTERNAL);    // Start timer 1 CCP Module time source;
   enable_interrupts(INT_CCP1);
   enable_interrupts(INT_CCP2);   // Setup interrupt on rising edge
   while(TRUE) {
         disable_interrupts(INT_CCP1);
         disable_interrupts(INT_CCP2);
         //A1=((ccp_1-7750)/7750)/0.125; //(Accleration=(T1-T2)/T2)/12.5%
         //A2=((ccp_2-7750)/7750)/0.125; //(Accleration=(T1-T2)/T2)/12.5%
         printf("\r\n\%8.4f us ,%8.4f us \r\n", A1,A2 );
Thanks you two guys help.
I think I didn't describe my question very well.
I mean the RS232 can't work.
The CCP_1 and CCP_2 is the value of capture.
But I didn't define CCP_1 and CCP_2, the code still be compiled by CCS Compiler.
I've checked the reference already. CCP_1 and CCP_2 is the value returned by CCP module. So I thought I need not to define CCP_1 and CCP_2.
I want to ask one more question. My question is,can I run two ISR at the same time?
Haplo
PostPosted: Fri Jun 25, 2004 6:45 am     Reply with quote
1. Your program does not have #fuses. It is good practice to always set the fuses.
2. What are the definitions for CCP_1 and CCP_2?
3. What do you mean you can't see anything on HT? Do you mean you can't see anything at all? Or you just can't see the expected values? Can you see the "\r\nHigh time (sampled every second):\r\n" message?
RS232 to HT
PostPosted: Fri Jun 25, 2004 6:48 am     Reply with quote
When you say you cant see anything from HT do you mean that nothing appears or you are getting garbage or not getting the right numbers?
It sounds like you have hardware connection problems. How do you have things hooked up from the board to the PC? Have you ever gotten anything to display in HT before to prove your hardware connections?
If you are getting nothing at all you need to comment out comment out both interrupts and everything in your main routine except the single printf() and so the program will do nothing but print over and over and get the hardware checked out first. Then add sections back and test until you get everything back in.
damsel
PostPosted: Fri Jun 25, 2004 7:38 am     Reply with quote
PostPosted: Wed Jun 29, 2005 3:10 pm     Reply with quote
I think that only one ISR can be served at same time.
that's, when one ISR is being executed, NO other interrupt can be served until first of them is finished.
However, you can define two levels of prioriry interrupts depending your PIC.
I hope my poor English can help you.
Alda 705
PostPosted: Wed Jun 29, 2005 3:11 pm     Reply with quote
Anonymous wrote:
Alfa 705
kender
PostPosted: Wed Jun 29, 2005 4:30 pm     Reply with quote
Here's another recent accelerometer-related topic.
http://www.ccsinfo.com/forum/viewtopic.php?t=23377[/url]
Re: Help me about CCP interupt
PostPosted: Thu Dec 22, 2005 2:51 am     Reply with quote
damsel wrote:
Hello everyone..
Please help me..
Thanks alot
#include <16f877.h>
long rise,rise2;
float A1,A2;
#int_ccp1
void isr1()  {
#int_ccp2
void isr2()  {
main() {
   while(TRUE) {
