Sonar - Ultrasonic Range Finder
jahan
PostPosted: Tue Jun 28, 2005 9:01 am     Reply with quote
I have a Sonar from Parallax and would like to use it with PIC16F877A.
the specs on Sonar says:
HOST must send a minimum of 2 uS (typical 5 uS) to device.
HOST waits for 750 uS.
Sonar will send a puls back minimum 115 uS to max 18.5 mS
all pulses are from 0 to 5V.
    |----|           |----------------------|                 5v
----|    |-----------|                      |---------------  0v
    HOST          Response from sonar
in Basic Stamp (using BS2) word it would look like this:
PIN5 = 0
PULSOUT PIN5, 5        // 5 uS
PULSIN PIN5, 1, Dist  // dist is a byte
now using dist variable they have a simple math to do the distance calculation.
anybody can help me with CCS C code for the sending a PULS and reading back a PULS?
thankx
valemike
PostPosted: Tue Jun 28, 2005 12:45 pm     Reply with quote
To send a signal for 5 microseconds:
Say you're using a 4MHz oscillator.
Thus, 4000000 / 4 = 1000000 hz ==> 1 microsecond per instruction.
A "NOOP" is an instruction that will take 1 microsecond. You will want to disable interrupts for a while to get a precise 5 us pulse:
disable_interrupts(GLOBAL);
delay_cycles(5);  // delay 5 no-ops to get 5 microseconds
Alternatively, you can use the function "delay_us(5)". Then you don't have to worry what oscillator speed you're using.
Now you have to wait approximately 750 microseconds to get a response. You would use the CCP module for that. However, i don't have any code for that. Maybe someone has some code handy that they can cut and paste in for you.
Mark
PostPosted: Tue Jun 28, 2005 1:25 pm     Reply with quote
Here is a cheap way of measuring the pulse. Note that if you do not get a pulse this code will hang. To prevent this, you would need to provide a timeout in the while() loops.
int16 getpulsewidth(void)
  setup_timer1(T1_DISABLED);
  set_timer1(0);
  // Wait for the signal to go high
  while (!input(PIN_RB5);
  setup_timer1(T1_INTERNAL|T1_DIV_BY_1);
  // Wait for the signal to go low.  We are measuring the signal
  while (input(PIN_RB5);
  return(get_timer1());
jahan
Does this work?
PostPosted: Tue Jun 28, 2005 2:12 pm     Reply with quote
Any comment would be great ...
#include <16F877A.h>
#device adc=8
#fuses NOWDT,RC, NOPUT, NOPROTECT, NODEBUG, BROWNOUT, LVP, NOCPD, NOWRT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9,stream=DEBUG)
int Sonar(void) {
   output_low (PIN_B1);                // set current state
   output_high(PIN_B1);                // bring high
   delay_us(5);                        // wait 5 uS
   output_low (PIN_B1);                // bring low
   while (!input(PIN_B1));             // wait to go high
   set_timer1(0);                      // Start ticking
   while(input(PIN_B1));               // wait until it goes low
   return get_timer1();                // read timer
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   while (TRUE) {
      fprintf(DEBUG,"%u",Sonar());
Mark
Re: Does this work?
PostPosted: Tue Jun 28, 2005 2:19 pm     Reply with quote
I would start and stop the timer since it is a 16 bit register being accessed via 8 bits and it is changing. Note that I changed the fuses as well. I doubt that you are using LVP which causes most people problems with hang up. I would recommend using the PUT to make sure things are stablized and you probably aren't using an RC as an osc source. Could be wrong though.
#device adc=8
#fuses NOWDT,XT, PUT, NOPROTECT, NODEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
int Sonar(void) {
   setup_timer_1(T1_DISABLED);
   set_timer1(0);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);           // Start ticking
   while (TRUE) {
valemike
Re: Does this work?
PostPosted: Tue Jun 28, 2005 2:21 pm     Reply with quote
If microseconds matter in your accuracy, remember to disable interrupts in Mark's code:
mypulsewidth = getpulsewidth();
If you don't do that, then you'll get jittery readings especially if you have other interrupts occurring all the time.
Humberto
PostPosted: Tue Jun 28, 2005 3:22 pm     Reply with quote
Just some comments regarding the selected #fuses options.
1) If microseconds matter in your accuracy, use a crystal in your oscillator instead of an RC.
2) Are you really using LVP ?
3) NOPUT ?
Keep well,
Humberto
jahan
PostPosted: Tue Jun 28, 2005 3:46 pm     Reply with quote
the #FUSES are the default from project wizard.
I have to re-eval all of them.
thank you everyone for your input. I'll test this ASAP and anybody is interested, I'll post the result.
Thankx again.
MNiCrO-BiT
ultrasonic lcd2x16
PostPosted: Thu Mar 06, 2008 9:05 pm     Reply with quote
Hello friends basket that can help me, I need to visualize the distance but in a lcd 2x16 but themselves not as to do it...
excuse for my badly English one
xjackal
PostPosted: Sun Mar 15, 2009 10:09 pm     Reply with quote
are you sure the below codes work?
ratheeshbr
Distance measuring using Ultrasonic sensor
PostPosted: Mon Mar 07, 2011 10:17 pm     Reply with quote
I too doing the same project to display the distance on an LCD. I tried with timer1 but not getting pulse width. May be a problem with my code. Can any one please guide me?
PostPosted: Mon Mar 07, 2011 11:06 pm     Reply with quote
Here's a version of the Pulsin() function for the CCS compiler:
http://www.ccsinfo.com/forum/viewtopic.php?t=42353
