sleep mode
Christophe
sleep mode
PostPosted: Fri Jun 24, 2005 6:55 am     Reply with quote
I'm measuring current consumtion by my PIC16LF877A; in normal operation : 3,2 mA; in sleep: 2,7 mA, what can be wrong? should be less no?
edit: what is a good way to limit current consumtion ? settings of interfaces, inputs and outputs?
PostPosted: Fri Jun 24, 2005 2:00 pm     Reply with quote
The following threads discuss how to reduce current usage in Sleep mode:
http://www.ccsinfo.com/forum/viewtopic.php?t=22320
http://www.ccsinfo.com/forum/viewtopic.php?t=17199
http://www.ccsinfo.com/forum/viewtopic.php?t=22402
http://www.ccsinfo.com/forum/viewtopic.php?t=19006&start=0
Christophe
PostPosted: Mon Jun 27, 2005 3:00 am     Reply with quote
as I go to sleep, pin_b0 stays a floating input pulled down to ground via 47K. Is that a problem?
problem solved...
you have to say: output_float ( pin_B0);
that is appearantly NOT the same as: input( pin_b0);
??? the manual says so
Christophe
PostPosted: Mon Jun 27, 2005 3:46 am     Reply with quote
IF you are in sleep, and the watchdog wakes you up; WHAT is happening? Is the watchdog resetting the PIC? or does the PIC continue executing instructions
Christophe
PostPosted: Mon Jun 27, 2005 4:22 am     Reply with quote
the guilty one is found: MAX223 Mad
If I disable the uart: setup_uart(FALSE); -which is connected to the MAX, I drain only 90uA..
