DS18B20 request
José
DS18B20 request
PostPosted: Mon Jun 27, 2005 4:08 am     Reply with quote
How can i use the DS18B20 (12bit) ???????
can i use the reset, read_byte, write_byte, read_bit, write_bit , from the DS1820??????
How implement a DS18B20 temp. mes.?????
Tkn´s in advance.
Mark
PostPosted: Mon Jun 27, 2005 5:53 am     Reply with quote
First you read the datasheet. Then you write a driver. Maxim already gives source code for that
http://dbserv.maxim-ic.com/quick_view2.cfm?qv_pk=2812
José
PostPosted: Mon Jun 27, 2005 7:01 am     Reply with quote
I already read this, and the sample code is in asm, but i like to use the ccs(but i´m begginer), and the reason for this post is , I need help for CCS code.
And as I said, all the information is for the DS1820, and not for the 18B20.
Note: 0% -> 100%, i´m in 5%.
Mark
PostPosted: Mon Jun 27, 2005 7:23 am     Reply with quote
Well my brain must be dead then cause this sure looks like C to me
//individual Serial #s and readings
#define DEVICES 4
int ROMS[DEVICES][8];
int TEMPS[DEVICES];
int GetTemperatures(int BASE)
  // init. the 1-Wire Master
  Initialize(BASE);
  // exit if no devices can be found
  if(Reset(BASE)) return(1);
  // find all individual Serial#s
  FindROMs(BASE);
  // Convert temp. and read devices
  ConvertT(BASE);
  ReadTemps(BASE);
  return(0);
void Initialize(int BASE)
  // Divide the clock
  outp(BASE+4,0x0F);
  // Generate INTs on reset and send
  outp(BASE+3,0x09);
int Reset(int BASE)
  outp(BASE,0x02);  // send reset
  WaitforInterrupt();
  if(inp(BASE+2) & 0x02)
    return(1);   //no presence found
    return(0);   //presence found
int FindROMs(int BASE)
  int loop;
  int dev;
  int TData[16];
  int RData[16];
  // reset RecoverROM and generate the
  // starting TData
  RecoverROM(NULL,TData,NULL);
  //run once for each device
  for(dev=0;dev<4;dev++)
    outp(BASE,0x01);   // send reset
    WaitforInterrupt();
    outp(BASE+1,0xF0);   // send SeachROM
    WaitforInterrupt();
    // enter Accelerator mode
    outp(BASE,0x02);
    // transmit the TDATA and receive
    // the RDATA.
    for(loop=0;loop<16;loop++)
      outp(BASE+1,TData[loop]);
      WaitforInterrupt();
      inp(BASE+1,RData[loop]);
    //decode recovered ROM and generate
    //next Search value
    RecoverROM(RDATA,TData,ROMS[dev]);
int ConvertT(int BASE)
  WaitforInterrupt();
  outp(BASE+1,0xCC);   // skip ROM
  WaitforInterrupt();
  outp(BASE+1,0x44);   // convert Temp.
  WaitforInterrupt();
int ReadTemps(int BASE)
  int dev,loop;
  int LSB,MSB;
    WaitforInterrupt();
    outp(BASE+1,0x55);   // match ROM
    WaitforInterrupt();
    // send 8 bytes of ROM code
    for(loop=0;loop<8;loop++)
      outp(BASE+1,ROMS[dev][loop]);
      WaitforInterrupt();
    outp(BASE+1,0xBE);   // read memory
    WaitforInterrupt();
    outp(BASE+1,0xFF);   // read LSB
    WaitforInterrupt();
    LSB = inp(BASE+1);
    outp(BASE+1,0xFF);   // read MSB
    WaitforInterrupt();
    MSB = inp(BASE+1);
    TEMPS[dev] = MSB<<8 + LSB;
// RecoverROM performs two functions. Given 16 bytes of receive data taken from
// the 1-Wire Master during a Search ROM function, it will extract the ROM code
// found into an 8 byte array and it will generate the next 16 bytes to be trans-
// mitted during the next Search ROM.
// RecoverROM must be initialized by sending a NULL pointer in ReceivedData. It
// will write 16 bytes of zeros into TransmitData and clear the discrepancy tree.
// The discrepancy tree keeps track of which ROM discrepancies have already been
// explored.
// RecoverROM also returns a value telling whether there are any more ROM codes to
// be found. If a zero is returned, there are still discrepancies. If a one is
// returned all ROMs on the bus have been found. Running RecoverROM again in this
// case will result in repeating ROM codes already found
int RecoverROM(int* ReceiveData, int* TransmitData, int* ROMCode)
  int loop;
  int result;
  int TROM[64];   // the transmit value being generated
  int RROM[64];   // the ROM recovered from the received data
  int RDIS[64];   // the discrepancy bits in the received data
  static int TREE[64];   // used to keep track of which discrepancy bits have
                         // already been flipped.
  // If receivedata is NULL, this is the first run. Transmit data should be all
  // zeros, and the discrepancy tree must also be reset.
  if(ReceiveData == NULL)
    for(loop = 0; loop < 64; loop++) TREE[loop] = 0;
    for(loop = 0; loop < 16; loop++) TransmitData[loop] = 0;
    return 1;
  // de-interleave the received data into the new ROM code and the discrepancy bits
    if((ReceiveData[loop] & 0x02) == 0x00) RROM[loop*4] = 0; else RROM[loop*4 ] = 1;
    if((ReceiveData[loop] & 0x08) == 0x00) RROM[loop*4+1] = 0; else RROM[loop*4+1] = 1;
    if((ReceiveData[loop] & 0x20) == 0x00) RROM[loop*4+2] = 0; else RROM[loop*4+2] = 1;
    if((ReceiveData[loop] & 0x80) == 0x00) RROM[loop*4+3] = 0; else RROM[loop*4+3] = 1;
    if((ReceiveData[loop] & 0x01) == 0x00) RDIS[loop*4] = 0; else RDIS[loop*4 ] = 1;
    if((ReceiveData[loop] & 0x04) == 0x00) RDIS[loop*4+1] = 0; else RDIS[loop*4+1] = 1;
    if((ReceiveData[loop] & 0x10) == 0x00) RDIS[loop*4+2] = 0; else RDIS[loop*4+2] = 1;
    if((ReceiveData[loop] & 0x40) == 0x00) RDIS[loop*4+3] = 0; else RDIS[loop*4+3] = 1;
  // initialize the transmit ROM to the recovered ROM
  for(loop = 0; loop < 64; loop++) TROM[loop] = RROM[loop];
  // work through the new transmit ROM backwards setting every bit to 0 until the
  // most significant discrepancy bit which has not yet been flipped is found.
  // The transmit ROM bit at that location must be flipped.
  for(loop = 63; loop >= 0; loop--)
    // This is a new discrepancy bit. Set the indicator in the tree, flip the
    // transmit bit, and then break from the loop.
    if((TREE[loop] == 0) && (RDIS[loop] == 1) && (TROM[loop] == 0))
      TREE[loop] = 1;
      TROM[loop] = 1;
    if((TREE[loop] == 0) && (RDIS[loop] == 1) && (TROM[loop] == 1))
      TREE[loop] = 1;
      TROM[loop] = 0;
    // This bit has already been flipped, remove it from the tree and continue
    // setting the transmit bits to zero.
    if((TREE[loop] == 1) && (RDIS[loop] == 1)) TREE[loop] = 0;
    TROM[loop] = 0;
  result = loop;   // if loop made it to -1, there are no more discrepancy bits
                   // and the search can end.
  // Convert the individual transmit ROM bit into a 16 byte format
  // every other bit is don't care.
    TransmitData[loop] = (TROM[loop*4]<<1) +
                         (TROM[loop*4+1]<<3) +
                         (TROM[loop*4+2]<<5) +
                         (TROM[loop*4+3]<<7);
  // Convert the individual recovered ROM bits into an 8 byte format
  for(loop = 0; loop < 8; loop++)
    ROMCode[loop] = (RROM[loop*8]) +
                    (RROM[loop*8+1]<<1) +
                    (RROM[loop*8+2]<<2) +
                    (RROM[loop*8+3]<<3) +
                    (RROM[loop*8+4]<<4) +
                    (RROM[loop*8+5]<<5) +
                    (RROM[loop*8+6]<<6) +
                    (RROM[loop*8+7]<<7);
  if(result == -1) return 1;   // There are no DIS bits that haven't been flipped
                               // Tell the main loop the seach is over
  return 0;   // else continue
Its not in CCS C but shouldn't be a problem to convert it.
Mark
PostPosted: Mon Jun 27, 2005 7:25 am     Reply with quote
Oh yeah, you can also use the search feature and use the code already posted here!
http://www.ccsinfo.com/forum/viewtopic.php?t=19255
http://www.ccsinfo.com/forum/viewtopic.php?t=12576&highlight=ds18b20
jds-pic
PostPosted: Mon Jun 27, 2005 7:28 am     Reply with quote
90% of what you need is right here;
http://www.ccsinfo.com/forum/viewtopic.php?t=19520
and this is life for an embedded systems programmer: borrow, adapt, improvise, overcome.
see also
http://www.ccsinfo.com/forum/viewtopic.php?p=37998
and
http://www.ccsinfo.com/forum/viewtopic.php?t=19795
how did i find these? by using the search feature.
jds-pic
PostPosted: Mon Jun 27, 2005 8:37 am     Reply with quote
Who does not know is as a blind person, and I am starting to see, and open my eyes.
So thanks for all info´s.
(in the search I had an error in the words, thought that it got a better result if it is looked for 1820 or 18b20, but not. But as it said I am to start to open the eyes.)
I wait in a next time not to commit as many basic errors.
Debtor to all the involved ones.
