UFAnders
Requesting motion-algorithm help |
Posted: Sat Jun 25, 2005 9:40 am |
Friends-->
I am using a tri-axis accelerometer with a PIC 18F2520 in hopes that I can eventually calculate velocity and displacement from the ADC results. Has anyone done this sort of thing?
I'm not looking to save myself effort, but moreso time - does anyone know of any algorithm resources that could help point me in the right direction?
Thanks for taking a look!
Anders |
Posted: Sat Jun 25, 2005 2:39 pm |
Question, is do you have the system gyro stabilised, or a seperate compass?. Three axes, do not maintain a position fix, unless you have data about the direction of the axes at any time, or keep the axes in a constant direction.
If the axes are stabilised, then you can sample at a fixed time interval, and simply sum the accelerations in each direction, so you maintain an integral of acceleration, which directly gives you velocity. A second integral, gives the actual position.
If the axes are not stabilised, you need to take a direction term as well, and then generate a sin, and cos from this, and use this to generate the sums. This is assuming that your vertical axis is stabilised by gravity. Otherwise you need a term in this direction as well.
treitmey
Posted: Sat Jun 25, 2005 5:52 pm |
Ttelmah, are you a teacher in real life? |
kender
Gyros |
Posted: Sat Jun 25, 2005 7:01 pm |
Hope you are not building an IMU for a cruise misile.
If you decide to go with gyros, check out Analog Devices' iMEMS gyros. These are, probably, the cheapest one s you can find. There are 2 warnings about the MEMS gyros, though. (1) You can damage them with vibration. (2) Readings drift with temperature. You can keep the gyros at a constant temperature, and/or you can compensate for the temperature (the gyros have an on-chip temperature sensor for that).
Nick |
