How to set states of pins in an software USART
arunb
PostPosted: Fri Jun 24, 2005 5:19 am     Reply with quote
Compiler: PCM
MCU : 16F877
I have setup a software USART on pins D4, D5 of PIC 16F877. The pins are connected to the Rxd and Txd pins of a 16F628.
Kindly advise what should be the state of the pins, High, low or float.
I am currently using float I find that most of the times data is not sent at all although the pin state changes to high ( both pins). Ins pite of this I can see no pulses on my scope.
But please remember communication takes place some times.
thanks
arunb
PostPosted: Fri Jun 24, 2005 5:44 am     Reply with quote
The transmit pin should be left high when not sending. Otherwise the receiver will not reliably see the 'start bit', which is a low.
arunb
RE:
PostPosted: Sat Jun 25, 2005 3:30 am     Reply with quote
Thanks for the reply.
Does the software USART do this autmatically ( making Txd high after transmission) ?? or do I have to do it ???
What about Rxd ???
thanks
arunb
Re: How to set states of pins in an software USART
PostPosted: Sat Jun 25, 2005 3:34 am     Reply with quote
arunb wrote:
Compiler: PCM
MCU : 16F877
thanks
arunb
just place in your code #use rs232 directive and you did not worry of the state of the Rx and Tx pin of your UART.
PostPosted: Sat Jun 25, 2005 5:42 am     Reply with quote
It is all automatic.
The 'stop' bit, is a high, and the pin is left in this state when the character is finished.
