akokyaw
Problem with output_b command |
Posted: Fri Jun 24, 2005 10:34 pm |
I am a newbie to CCS C compiler. I want to try a led blink program. I have a problem with output_b command. The problem is I can get blinking led except the pin 3 of portb. The version of IDE is 3.6 and PCM is 3.050.
Thanks in advance,
ak
I used pic16f877 and the source code as follows:
#include <16F877.H>
#fuses XT,NOWDT,NOPROTECT
#use DELAY(clock=4000000)
#use fast_io(B)
set_tris_b(0x00);
OUTPUT_B(0x00); // Set all pins low
OUTPUT_B(0xff); // on the I/O port pin
OUTPUT_B(0x00); // on the I/O port pin
Posted: Fri Jun 24, 2005 11:25 pm |
Go to the CCS FAQ page. Look in the first section, at the question on
"Why isn't Port B, pin 3, working ?"
http://www.ccsinfo.com/faq/ |
akokyaw
output_b problem |
Posted: Sat Jun 25, 2005 6:20 am |
Thanks man. It helps a lot. ![Idea](images/smiles/icon_idea.gif) |
