timer1 using for count
hamza bilgen
PostPosted: Thu Jun 23, 2005 3:51 pm     Reply with quote
when the ext1=1 , timer 1 must run and when timer1 is full ,rb7 is on. but as soon as the ext1=1 rb7 is on why ? i dont understand. because timer must wait 12.5 ms but it dont wait.
what is wrong?
#int_timer1
void tmr1_isr()
output_bit( PIN_B7, 1);
disable_interrupts(INT_TIMER1);
#int_ext1
void rb1_isr()
set_timer1(45000);
these are main's code samples about timer1
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1|T1_DISABLED );
enable_interrupts(global);
enable_interrupts(int_ext);
enable_interrupts(int_ext1);
set_tris_d(0x00);
set_tris_b(0b00000011);
PostPosted: Thu Jun 23, 2005 5:03 pm     Reply with quote
I don't see that Timer1 is enabled. Here, you have disabled it:
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1 | T1_DISABLED );
PostPosted: Fri Jun 24, 2005 2:26 am     Reply with quote
sorry i write wrong
i am correcting
#int_timer1
void tmr1_isr()
#int_ext1
void rb1_isr()
set_timer1(45000);
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1 );
set_tris_d(0x00);
