Problem with ADC input
Stewie82
PostPosted: Wed Jun 22, 2005 2:02 am     Reply with quote
I am inputting a 10k potentiometer on a 16F819. This chip is a 10 bit ADC, so am I correct in saying that I am basically reading in a number between 0 and 1024? Anyways, I store the input as a long and pass it to a function to output to two, 7 segment displays. I want to limit the adjustability of the potentiometer to about 60, which is why I am dividing the long by 17.0 (1024/17~=60).
My output on the display only goes between 1 and 14. Can any of you see what I am doing wrong?
Also, is there any other frequency I can set this chip to run at? or will I always want to do 4 MHz?
#include <16F819.h>
#FUSES INTRC_IO,NOPROTECT,NOWDT,PUT,BROWNOUT, NOMCLR, NOLVP
#define VALVE_OUTPUT PIN_A2
#define LED_DISPLAY_LS_0 PIN_B0
#define LED_DISPLAY_LS_1 PIN_B1
#define LED_DISPLAY_LS_2 PIN_B2
#define LED_DISPLAY_LS_3 PIN_B3
#define LED_DISPLAY_MS_0 PIN_B4
#define LED_DISPLAY_MS_1 PIN_B5
#define LED_DISPLAY_MS_2 PIN_B6
#define LED_DISPLAY_MS_3 PIN_B7
long read_adc_average(int channel) {
   long value;
   int i;
   set_adc_channel(channel);
   value=0;
   for ( i=0 ; i<8 ; i++ ) {
      value += read_adc();
      delay_ms(2);
   /* divide by 8 */
   value = value / 8;
   return value;
void init_adc(void) {
   setup_adc( ADC_CLOCK_INTERNAL );
   setup_adc_ports( RA0_RA1_RA3_ANALOG );
void write_display(long led_num){
      if(led_num != 0){
         if(led_num%10 == 0){
            output_low(LED_DISPLAY_LS_0);
            output_low(LED_DISPLAY_LS_1);
            output_low(LED_DISPLAY_LS_2);
            output_low(LED_DISPLAY_LS_3);
         else if(led_num%10 == 1){
            output_high(LED_DISPLAY_LS_0);
         else if(led_num%10 == 2){
            output_high(LED_DISPLAY_LS_1);
         else if(led_num%10 == 3){
         else if(led_num%10 == 4){
            output_high(LED_DISPLAY_LS_2);
         else if(led_num%10 == 5){
         else if(led_num%10 == 6){
         else if(led_num%10 == 7){
         else if(led_num%10 == 8){
            output_high(LED_DISPLAY_LS_3);
         else if(led_num%10 == 9){
         if(led_num <10){
            output_float(LED_DISPLAY_MS_0);
            output_float(LED_DISPLAY_MS_1);
            output_float(LED_DISPLAY_MS_2);
            output_float(LED_DISPLAY_MS_3);
         else if(led_num/10 == 1){
            output_high(LED_DISPLAY_MS_0);
            output_low(LED_DISPLAY_MS_1);
            output_low(LED_DISPLAY_MS_2);
            output_low(LED_DISPLAY_MS_3);
         else if(led_num/10 == 2){
            output_low(LED_DISPLAY_MS_0);
            output_high(LED_DISPLAY_MS_1);
         else if(led_num/10 == 3){
         else if(led_num/10 == 4){
            output_high(LED_DISPLAY_MS_2);
         else if(led_num/10 == 5){
         else if(led_num/10 == 6){
         else if(led_num/10 == 7){
         else if(led_num/10 == 8){
            output_high(LED_DISPLAY_MS_3);
         else if(led_num/10 == 9){
void main(void) {
   long user_input_adc_value;
   long sensor_input_adc_value;
   long display_value = 0;
   init_adc();
   while ( 1 ) {
      user_input_adc_value = read_adc_average(0);
      sensor_input_adc_value = read_adc_average(1);
      delay_ms(50);
      output_high(VALVE_OUTPUT);
      delay_ms(50);
   //   output_low(VALVE_OUTPUT);
   display_value = user_input_adc_value/17.0;
      write_display(display_value);
[/quote]
Stewie82
PostPosted: Wed Jun 22, 2005 2:11 am     Reply with quote
After some testing, I am thinking that the ADC is actually only 2^8 or 256.....what am I confused about here?
Paolino
PostPosted: Wed Jun 22, 2005 2:51 am     Reply with quote
Add
#device adc=10
if you want to read 10 bit analog signals.
Best regards.
Paolo.
asmallri
PostPosted: Thu Jun 23, 2005 2:10 am     Reply with quote
The ADC is being read too soon after the channel is selected. You need to wait for the output to "settle". I use 25us on an 18F452, I don't know what settling time your processor requires.
Regards, Andrew
