dongseong
bits order change |
Posted: Wed Jun 22, 2005 11:13 pm |
Is there function available on CCS-C to change the bit order?
I want to change as follow;
bit 7 --> bit 0
bit 6 --> bit 1
bit 5 --> bit 2
bit 4 --> bit 3
bit 3 --> bit 4
bit 2 --> bit 5
bit 1 --> bit 6
bit 0 --> bit 7
Dong ![Smile](images/smiles/icon_smile.gif) |
dongseong
Thanks |
Posted: Thu Jun 23, 2005 4:44 am |
Thanks!
It is complicated then I expected. ![Very Happy](images/smiles/icon_biggrin.gif) |
treitmey
Posted: Thu Jun 23, 2005 8:39 am |
Try
#include <16F877.h>
#device *=16
#use delay(clock=16000000)
#fuses HS,NOWDT,NOLVP,PROTECT,PUT,BROWNOUT
#use rs232(baud=19200,xmit=PIN_E0,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#case
#zero_ram
#define VER_MAJOR 1
#define VER_MINOR 00
char swap_bits(char test);
//======================= Main ==============================
char test,x,y,result;
fprintf(DEBUG,"Starting\n\r");
fprintf(DEBUG,"Bit swap %u.%02u\n\r",VER_MAJOR,VER_MINOR);
result=0;
test++;
fprintf(DEBUG,"t=0x%X ",test);
fprintf(DEBUG,"r=0x%X\n\r",swap_bits(test));
//========================== swap_bits ============================//
char swap_bits(char test) //print out any errors that occured
char result=0,x;
for( x=0;x<8;x++)
if(bit_test(test,7-x))
bit_set(result,x);
bit_clear(result,x);
return(result);
Posted: Thu Jun 23, 2005 10:02 am |
I built a slightly different one that works great. I looked around for various ways of shifting the bits around, but they all took more space and time than this.
It's not portable.
//reverse()
// - name deleted -
//08 June 2004
//This function takes an integer (or any 8-bit value) and reverses
//the bit order. I built it because the folks at Epson decided
//that their chip would store things in reverse order.
int reverse( int backwards )
//First, we define each bit in both the backwards and forwards
//integers.
#bit bkwd_0 = backwards.0
#bit bkwd_1 = backwards.1
#bit bkwd_2 = backwards.2
#bit bkwd_3 = backwards.3
#bit bkwd_4 = backwards.4
#bit bkwd_5 = backwards.5
#bit bkwd_6 = backwards.6
#bit bkwd_7 = backwards.7
int forwards;
#bit fwd_0 = forwards.0
#bit fwd_1 = forwards.1
#bit fwd_2 = forwards.2
#bit fwd_3 = forwards.3
#bit fwd_4 = forwards.4
#bit fwd_5 = forwards.5
#bit fwd_6 = forwards.6
#bit fwd_7 = forwards.7
//Now we just assign the bits directly.
//It works out to 24 lines of assembly.
fwd_0 = bkwd_7;
fwd_1 = bkwd_6;
fwd_2 = bkwd_5;
fwd_3 = bkwd_4;
fwd_4 = bkwd_3;
fwd_5 = bkwd_2;
fwd_6 = bkwd_1;
fwd_7 = bkwd_0;
return( forwards );
Neutone
Posted: Thu Jun 23, 2005 10:39 am |
Anonymous wrote: | I built a slightly different one that works great. I looked around for various ways of shifting the bits around, but they all took more space and time than this.
It's not portable.
//reverse()
// - name deleted -
//08 June 2004
//integers.
int forwards;
fwd_0 = bkwd_7;
fwd_1 = bkwd_6;
fwd_2 = bkwd_5;
fwd_3 = bkwd_4;
fwd_4 = bkwd_3;
fwd_5 = bkwd_2;
fwd_6 = bkwd_1;
fwd_7 = bkwd_0;
return( forwards );
If you really want to minimize space and time this may inprove things some. It should reduce to 17 lines of assembly.
//integers.
int forwards;
forwards=0;
if bkwd_7
{ fwd_0=1;
if bkwd_6
{ fwd_1=1;
if bkwd_5
{ fwd_2=1;
if bkwd_4
{ fwd_3 =1;
if bkwd_3
{ fwd_4=1;
if bkwd_2
{ fwd_5=1;
if bkwd_1
{ fwd_6=1;
if bkwd_0
{ fwd_7=1;
return( forwards ); |
Humberto
Posted: Thu Jun 23, 2005 5:13 pm |
This way works great also and is shortest and fastest.
int8 reverse( int8 backwards )
int8 result=0;
int8 x;
for( x = 0; x < 8; x++)
if(bit_test(backwards,7))
{ bit_set(result,0); }
{ bit_clear(result,0); }
backwards = backwards << 1;
rotate_right( &result, 1);
return(result);
Humberto |
Posted: Fri Jun 24, 2005 7:21 am |
Humberto wrote: |
PIC18F458 and PCH v3.226 this requires 17 instructions, 38 bytes.
Shorter, maybe, depends on processor type and compiler version. Faster, no. Because of the loop more instructions are executed than in the Guest/Neutone version.
Just for fun I modified your code to make it even shorter:
- A loop counting down to 0 saves 2 instructions
- Result is already initialized to 0, so bit_clear unneeded, saves another 2 instructions.
- The shift instruction requires two assembly instructions, saved one instruction by replacing it with rotate.
New and improved version: 12 instructions, 28 bytes.
Code: | int8 reverse( int8 backwards )
int8 result=0;
int8 x;
x = 8;
do
if (bit_test(backwards,7))
bit_set(result,0);
rotate_left( &backwards,1);
} while (--x);
return result;
Humberto
Posted: Fri Jun 24, 2005 9:50 am |
Hi ckielstra,
I like your improvements !
This function I made it once to solve a PCB error.
I never tryied to optimize it because it just run as expected. Yesterday I made
a simple test against the code posted by "guest" and I realized that it perform
better, then I posted as is. I like this kind of discutions.
Have a nice weekend,
Humberto |
MGP
Posted: Fri Jun 24, 2005 11:00 pm |
If you have the program memory space available, the fastest way is with a 256 byte lookup table (array). |
