while(TRUE) size limit
JoeO
PostPosted: Wed Jun 22, 2005 7:27 am     Reply with quote
Hello
I have a large while(TRUE) loop in my main routine. Above a certain size of code (in the while loop) the goto function that implements the while loop goto's some strange area, reduce the code and it goto's the correct place. Is there some fundamental limit within the compiler?
i.e (the dissassembly screen)
584: while(TRUE)
585: {
....lots of code
742: }
000ACD 285D GOTO 0x5d
which is obviously broken, whereas: remove some of the code in the while loop and
584: while(TRUE)
585: {
586: while(!kbhit())
587: {
000613 1A8C BTFSC 0xc, 0x5
000614 2E17 GOTO 0x617
742: }
0007F9 2E13 GOTO 0x613
whis is OK. I am using a 16F628, CCS ver 3.226, mplab v7.00.
Whats going on?
PostPosted: Wed Jun 22, 2005 1:20 pm     Reply with quote
I tried to duplicate your problem but could not do so.
I compiled the program below with PCM vs. 3.226, and
it made a large loop that starts at address 0x28E:
0000                01624 .................... while(1)
0000                01625 ....................   {
0000                01626 ....................    a = 123.45678;
028E 30DF       01627 MOVLW  DF
It goes down to address 0x7B3 (near the end of ROM for the 16F628)
and jumps back up to 0x28E properly.
07B1 0877       02967 MOVF   77,W
07B2 00B1       02968 MOVWF  31
0000                02969 ....................   }
07B3 2A8E       02970 GOTO   28E
0000                02971 ....................
0000                02972 .................... }
0000                02973 ....................
07B4 0063       2974 SLEEP
I think you need to post a test program that demonstrates the
problem. My program below creates a large while() loop but
it doesn't show a problem.
#include <16F628.H>
#use delay(clock = 4000000)
#include <math.h>
float a;
float b;
float c;
float d;
float result;
   a = 123.45678;
   b = 456.78901;
   c = 789.01234;
   d = 246.13579;
   result = a + b + c + d;
   result = a - b - c - d;
   result = a * b * c * d;
   result = a / b / c / d;
PostPosted: Wed Jun 22, 2005 3:11 pm     Reply with quote
I have thousands of lines in a do{ }while(true); loop. I don't think there's any limit beyond what the chip can physically hold.
treitmey
PostPosted: Wed Jun 22, 2005 4:14 pm     Reply with quote
Wow Surprised
PostPosted: Wed Jun 22, 2005 4:18 pm     Reply with quote
Or, mark it down as Rolling Eyes
Edited to add:
To be fair, he probably meant he has a couple thousand lines of
ASM code in his loop, which is possible. Treitmey and I thought
he meant 2000 lines of C source code.
