how to sleep after 2 minutes inactivity
jahan
PostPosted: Thu Jun 16, 2005 2:23 pm     Reply with quote
16F628A
RB1: LED
RB0: Pull-up with Push button
normal operation: LED blinks
Question:
How can make PIC go to sleep if push button has not been pressed for 2 minutes (2 minutes idle)?
AND how do I wakeup the PIC when the push button is pressed?
same code please ... Shocked
valemike
PostPosted: Thu Jun 16, 2005 4:29 pm     Reply with quote
#INT_TIMER1                        // This function is called every time
void clock_isr()                   // timer 1 overflows (65535->0), which is
{                                   // approximately 19 times per second for
    if (GLOBAL_keypad_inactivity_timer > 0)
        GLOBAL_keypad_inactivity_timer--;
       if (!GLOBAL_keypad_inactivity_timer)
        set a flag that tells you that you should go to sleep.
       // if your inactivity flag is set, then go to sleep here i guess.
Say i get 19 interrupts per second.
There are 19 * 60 interrupts per minute
There are 2 minutes.
So 2 * 19 * 60 = 228.
set GLOBAL_keypad_inactivity_timer to 228 when you want to start the inactivity counter. If there is activity, then you have to reset it back to 228.
-Wake up from sleep during an edge transition of RB0. Read the manual.
- Use time delays (e.g. delay_ms()) to blink your LED,
I've shown the pseudocode and steps. i guess the full implementation is left as an assignment. (or do an exhaustive google search )
-Mike Twisted Evil
valemike
PostPosted: Thu Jun 16, 2005 4:31 pm     Reply with quote
228 should be 2280. Embarassed
jahan
and how do I wakeup from RB0?
PostPosted: Thu Jun 16, 2005 4:46 pm     Reply with quote
Thankx Mike,
I get the idea; Now how do I wake the PIC by lowering RB0?
Thankx again
valemike
PostPosted: Thu Jun 16, 2005 4:52 pm     Reply with quote
When RB0 goes low, and you have falling edge interrupts enabled (#int_ext), then the PIC will wake up.
jahan
int_ext ??
PostPosted: Thu Jun 16, 2005 4:55 pm     Reply with quote
when RB0 does interrupt the PIC, do you know if the program starts from beginning ? or continues from next statment after sleep?
valemike
PostPosted: Thu Jun 16, 2005 6:08 pm     Reply with quote
It starts at the next statement after sleep.
I believe you are advised to put a NOOP in the statement after sleep.
delay_cycles(1); ought to do the trick.
I recently wrote a program using sleep in assembly,and i put the noop in there. Not sure what to do in CCS.
jds-pic
PostPosted: Fri Jun 17, 2005 1:06 am     Reply with quote
in foobar-ioreg.h
ext_int_edge(L_TO_H);      // external interrupt is tied to the switch
enable_interrupts(INT_EXT);
in function definitions
#int_ext
void pushbutton_isr() {             // got an pushbutton INT
   pushbutton_flag=TRUE;
#define TIMEOUT_USERWAIT   20    // seconds
in main()
   int result=DELAY_COMPLETE;
   int firstpass=TRUE;
   internal_eeprom(INCREMENT16, EEPROM_RESET, DONT_CARE);
   if (internal_eeprom(READ16, EEPROM_FW_VER, DONT_CARE) != (int16)FW_VERSION ) {
      internal_eeprom(INCREMENT16, EEPROM_FLASH_UPD, DONT_CARE);
      internal_eeprom(WRITE16, EEPROM_FW_VER, (int16)FW_VERSION);
   #include "foobar-ioreg.h"    // configure register and timing control defs
   lcd_preinit();
   lcd_init();
   while(TRUE) {
sleepnow:   // that awful philw influence... :*)
      pushbutton_flag=FALSE;
      firstpass=TRUE;
      lcd_init();
      lcd_clear();
      printf(lcd_putc,"   (sleeping)");   // debug only...
      set_power_mode(SLEEP);
      sleep();                            // wait for pushbutton INT
      delay_ms(1);
      set_power_mode(RUN);
mainloop:
      lcd_clear();
      timeout_flag=FALSE;
      while (serial_port_byte_avail())   // clear serial buffer
         getch();
      switch (detect_module(MOD_NONE)) {
         case MOD_BOTH: {  result=display_message(MSG_TWOMODS,MOD_BOTH,TIMEOUT_USERWAIT); break; }
         case MOD_FAIL: {  result=display_message(MSG_MODFAIL,MOD_FAIL,TIMEOUT_MODFAIL) ; break; }
         case MOD_RSFP:  {  result=display_data(MOD_RSFP); break; }
         case MOD_RXFP:  {  result=display_data(MOD_RXFP); break; }
         case MOD_NONE: {  if (firstpass) {
                              result=display_message(MSG_BANNER,MOD_NONE,TIMEOUT_BANNER);
                              if (INPUT(PIN_PB_SWITCH)) {     // user requests flash upgrade
                                 user_mode_request();
                              if (serial_port_byte_avail()) { // PC requests host mode
                                 host_mode_request();
                              if (result==DELAY_MOD_FLAG)
                           result=display_message(MSG_INSERT,MOD_NONE,TIMEOUT_USERWAIT); break; }
         default:       {  break; }
      firstpass=FALSE;
      if (result==DELAY_SERIAL_FLAG) {    // handles case where module
         result=DELAY_COMPLETE;           // is present at power-up.
      if (result!=DELAY_COMPLETE)         // i.e. module state change or button press
         goto mainloop;
      goto sleepnow;                      // else it was timeout, so hit the hay
      // should never ever get here!
      reset_cpu();
Steven
PostPosted: Fri Jun 17, 2005 5:25 am     Reply with quote
I tested your code and it's ok but i dont get it how you
can create something else ( accept lcd shout down ).
Let me explain myself:
if (GLOBAL_keypad_inactivity_timer == 0)
// shut lcd down
doSleep();
if i run this in main loop i loos much of power.
The code is acting weird and i cant get the right performance...
Do you have some extended solution ?.
valemike
PostPosted: Fri Jun 17, 2005 9:10 am     Reply with quote
Haven't seen your code, so i'm making a guess...
Do you have your wdog enabled? If so, then this will wake you up from sleep fairly quickly.
And do you decrement your inactivity timer, such that it wraps from 0 to 0xffff? You should not decrement past 0, or else you won't be able to sleep again for a long time.
Steven
PostPosted: Sun Jun 19, 2005 5:38 am     Reply with quote
If i go directly on sleep() function
// shut lcd down
sleep();
i stuck in the sleep mode direkt after clicking on reset.
I can not execute the rest of the program ( and the program in not waiting for 2 minutes to go to sleep ). He hits the sleep part directly after press on reset... Why is he not waiting 2 minutes to go to sleep.
All other stuff is working. If i shut just lcd this will work but the part above will not ?
