hawk123
step motor AN906 |
Posted: Thu Jun 16, 2005 4:39 pm |
Hi, I am using AN906 to design a step motor system. But it seems the program Microchip provided is not right because the values of the timer0, timer2 and micro-step are not right. For example, they use andlw 0x07 and I think that should be andlw 0x0f. Who can help me to determine the value of timer0 and time2 when using microstep control? Thanks a lot. |
Posted: Fri Jun 17, 2005 3:23 am |
andlw 0x7, is correct.
Why not just try the code. It does work.
The key thing to understand, is that they are using eight 'micro steps' to each 'half step'. The andlw 07, selects these micro steps, and adjusts the PWM values to the two outputs.
There are four bits controlling the 'main' steps.
If you look at a standard step 'table' for a half stepping motor, you get:
A B C D
0 1 1 0 0
1 0 1 0 0
2 0 1 1 0
3 0 0 1 0
4 0 0 1 1
5 0 0 0 1
6 1 0 0 1
7 1 0 0 0
(Hopefully the 'code' tab will keep the table aligned...).
Now you will see that there are eight phases, and each has just one or two poles energised. What has to be done, is that the power feeds to the possible pairs, come from the two PWM outputs, and then microstepping is achieved by adjusting the ratio of power smoothly from the 'off' state to the fully 'on' state, with the timing following a sinusoid. The Microchip example, uses eight possible values for this, effectively dividing each half step, into eight further states. This gives sixteen 'micro steps' to the full step.
So, though thre are sixteen microsteps, there are only eight 'sub positions' used to the half step.
hawk123
Thank you |
Posted: Fri Jun 17, 2005 10:33 am |
Thank you very much! |
hawk123
Thank you |
Posted: Fri Jun 17, 2005 10:34 am |
