Christophe
testing a string |
Posted: Fri May 27, 2005 1:28 am |
Hi I am communicating with a device via a small protocol: This is our bytestring:
C-cmd1-cmd2-cmd3-cmd4-DL-D1-D2-....-Ddl
C = 0xAA = you're getting a command
CMD1-CMD2-CMD3-CMD4 = the command; eg. BATT/ADAP (means send me the battery-voltage)
DL = length of the data that is now coming
D1...Ddl = DATA itself
The question is now, how can I easily state in CSS-C :
IF ( the command = "BATT")
do_the_required();
ELSE IF ( CMD1,CMD2,CMD3,CMD4 == "BRAI" )
do_an_other_command();
These are the variables for the data:
Code: | char data[50] ;
char *p;
p = data; |
appreciate your replies.. |
libor
Posted: Fri May 27, 2005 4:11 am |
char *p;
char tempstr[5];
p = data;
strcpy(tempstr, "BATT"); //strncmp works with both strings in RAM only
if (strncmp(p+1, tempstr, 4))
do_batt_things();
strcpy(tempstr, "BRAI");
do_brai_things();
| as an alternative you can concatenate all possible command words into one string, and search thru it for the received word. The index at which the word is found would serve as a parameter for the switch jump. strstr() has no n parametered version so you have to delimit your string manually by a 0.
Code: | strcpy(allcmdstr, "BATTBRAICMD3CMD4ETC0");
strncpy(tempstr, p+1, 4);
tempstr+4 = 0; //you can save all this copying if you extract the DL parameter earlier and replace it with a 0 in place.
index = strstr(allcmdstr, tempstr);
switch (index) {
case 0: do_BATT(); break;
case 4: do_BRAI(); break;
// ...etc
default: do_syntax_error(); break;
| If execution speed is of concern, I would rather test only some significant characters one-by-one to make a switch-case selection tree, though it would result a less readable/maintanable code and limited syntax checking.
These are untested codes typed directly here, may have errors, use them as clues only. |
Christophe
Posted: Wed Jun 15, 2005 5:40 am |
Code: | I've tested that 1st piece of code, and it's NOT working:
char data[47];
char *p;
char command[5];
p = data;
// Commando gaan toetsen:
// Batterij commando?
strcpy(command,"BATT");
if (strncmp(p+1,command,4))
putc('B');
// Adapter commando?
strcpy(command,"ADAP");
putc('A');
if I send: 170,65,68,65,80,0 (170,A,D,A,P,0) the program returns 66,65 (shouldn't return 66)
help wanted!
edit: this returns 1 (int8)
Code: | strcpy(command,"BATT");
i = strncmp(data[0],command,4);
putc(i); |
